I bought one from China to test.
It worked for about two minutes.
I asked for a replacement - they sent one.
That worked for about two minutes.
If you're going to try them - get them from somewhere it's easy to get replacements / refunds.
When I converted my last motorhome to g4 led lights I found I needed to add small circuit boards to each fitting to regulate the voltage to exactly 12v. They were very voltage sensitive.
I have not had to do anything even after six months living in the van on ehu. Only time I had to change a power supply for LEDs was a fitting in the house that used G4S. The current draw was so small the old PSU would not work and I had to fit an led one.
For the avoidance of doubt, I have LEDs throughout the van, car and home - it's just that that particular type, from one particular Chinese vendor, caused me problemsYes some are polarity sensitive but I have the wit to turn them round.
Yes I noticed some buck converter regulators work at 1MHZ. Is there any need for that? The ones I've got are 900hz so will be ok, there's no regulators on the leds I ordered.Be a little wary where you get your LED from. Some on Ebay give off so much RF radiation when operating they can whipe out your TV or Phone signals. Also get those which are advertised 12/24 volt as these include the required regulator. If you get with one click (Amazon) their return and refund system is second to none. Its worth paying that little bit more for LEDs that will outlive you.
C.
