Malcyb
- Aug 2, 2020
- 28
- 6
- Globecar PVC
- Since 2019
Hi,
We‘ve just taken our van out for its first proper outing (a few days in rural Shropshire), and it’s the first time we’ve had to deal with propane cylinders; our previous, first, van had an underslung LPG tank. While we contemplated whether to get a refillable system we got an 11 kg bottle to be getting along with. We’ve discovered a fairly pronounced smell of gas at the point I open the tap on the cylinder which doesn’t go away, and a slight hiss from the top of the cylinder. Though I don’t have any leak detector spray to prove it, I don’t think the problem is the connection to our hose, since after shutting the tap on the cylinder, there was a sharp hiss of gas as soon as I started to loosen the screw a little so I think it was a good seal. So I think it must be the tap on the cylinder that’s at fault. Is this likely? I’ve obviously no idea how fast the leak is, but we’ve used the stove once and we’re still alive. I was contemplating just shutting the tap when we’re not using any gas, but would it be unwise to use it at all. Even though this will cause us a lot of hassle for a few days it would be better than having a disaster...
