There are quite a few on Amazon.Kitchen tap broken any ideas where i can get one the same. Bavaria moho.
Search caravan taps on eBayThere are quite a few on Amazon.
Not leaking base has broken.Define broken. If it's leaking search under our user name for about 8 weeks ago. We had leaking tap similar to yours.
have you tried Rhino Installs Preston if your near there he is good.Next thing is, wait til you find a tap but then cannot get it fitted. I have had to book ours in for tap replacement in Aberdeen in late September after our Shetland trip No one here in the North west either responds to enquires or is far too busy to do the job.
Cant see that as being a problem as the micro switch just completes the circuit to switch the pump on, and the water flow valve will still work regardless. If it’s not connected (electrics) then the water valve will still operate like a ordinary tap.Think i have found one on ebay but it has a microswitch. Mine isnt microswitched so can i just not use the microswitch bit?
I got a tap from toolstation they have plenty for around £30 https://www.toolstation.com/ebb-flo-filey-mono-mixer-kitchen-tap/p38515Cant believe changing a tap could be so problematic. If you buy on line you have all the mither returning if wrong. Im going to have to wait until my Bavaria dealer gets back to me and pay their in no doubt extortionate price.
Did it connect easily to the flexi hosesI got a tap from toolstation they have plenty for around £30 https://www.toolstation.com/ebb-flo-filey-mono-mixer-kitchen-tap/p38515
YesDid it connect easily to the flexi hoses
My concern is the tails being the same size to fit the new tap !View attachment 650038
I put this one in a couple of weeks ago, from Toolstation, it's better than the original.
Use the existing tails, I did I just replaced the "O" ringsMy concern is the tails being the same size to fit the new tap !
He is mega busy and it’s probably too small a job for him. I have used him beforehave you tried Rhino Installs Preston if your near there he is good.
Hi yes i use Rhino. I think he prefers larger work i recently asked him to investigate my solar which may need some remedial work and he hasn’t replied unfortunately, given the amount of other work i have had done there. I agree possibly too busy.He is mega busy and it’s probably too small a job for him. I have used him before
Got free returns with Amazon so will keep going until i find the correct one.
For me the biggest problem is that I have to move the fridge out to get to it in the first place!Cant believe changing a tap could be so problematic. If you buy on line you have all the mither returning if wrong. Im going to have to wait until my Bavaria dealer gets back to me and pay their in no doubt extortionate price.
