Fireman Sam
- Sep 8, 2012
- 1,421
- 2,513
- Class C
- Only since 2012, but I towed for many years
Diet of course. You wouldn't want to add fat to the fire, would you.
Nowt wrong with BCF. A chap said to me "use that, and it could destroy one of your lungs". I replied yes, but I have two lungs, and one fire.Got 1x AFFF 1x BCF 1xCO2 1x BCF 1x CTC, also have in the garage 1xLPP, 1xFB5x 4 x 25m 70mm, 1x 10.5 1x 13.5
Although my FS training was 1969, I still believe you cannot be to complacent. ( BIT of an in joke)
Any before you respond I know some of the above were outlawed at the same time as 50ft ladders with big wheels.
£65, they are 'avin a larf.....it's a bloody rubber car mat on a stick.Broken Link Removed
General Fires in Open Areas, that must be Campervans 100%
- £65.09
- Free Postage
You cant use that mate (Halon) its bad for the ozone! my reply, "and a race car on fire is good for the ozone then is it ?" then some other words!!!Nowt wrong with BCF. A chap said to me "use that, and it could destroy one of your lungs". I replied yes, but I have two lungs, and one fire.![]()
I'm just sat here trying to work out why no one has Co2. Surely a better choice?? That bl**dy powder ruins everything, (including circuit board electrical devices), once it get free. Must look into the Co2 thing.You cant use that mate (Halon) its bad for the ozone! my reply, "and a race car on fire is good for the ozone then is it ?" then some other words!!!
There was nowt wrong with the pump escape...........Saved many lives.outlawed at the same time as 50ft ladders with big wheels.
Oops! Haven't got one at all, not even crossed my mind until I read this post..
Warning! Warning Don't park next to me until I get one.![]()
CO2 just damages all the electrics the same but it takes longer to showI'm just sat here trying to work out why no one has Co2. Surely a better choice?? That bl**dy powder ruins everything, (including circuit board electrical devices), once it get free. Must look into the Co2 thing.
CO2 (Carbon Dioxide) Fire Extinguishers contain only pressurised CO2 gas and therefore leave no residue. This type of extinguisher is suitable for use on fires involving burning liquids (Class B fires), but is also a good solution for quenching fires involving computer equipment and other electrical appliances, as it does not cause damage to the electrical items and does not cause the system to short circuit. It is important to remember that when using CO2 extinguishers there is a possibility that once the smothering CO2 gas has floated away the fire may re-ignite if the source of the fire is not removed (eg switching off the power supply) or if the materials are still very hot. Please be aware that CO2 extinguishers that are not fitted with double-lined swivel horns may cause your fingers to freeze to the horn during the deployment of the extinguisher. Always select CO2 extinguishers with frost-free horns. CO2 extinguishers are NOT suitable for deep fat fryers, as the strong jet from the extinguisher carries the burning fat out of the fryer and into the room!
Sorry Roger, trying nothing!Nice try Toots
Maybe if you took the cooker out of the loo, you would sleep untroubled?t's too easy in our MH to put the cooker rings on by brushing against the controls on a night-time loo trip.
Maybe if you took the cooker out of the loo, you would sleep untroubled?![]()
a 2k extinguisher just by hab door
