Is the bit in this article that says because the isolator is rated at 300A at 48V it is good for 1,200A at 12V true? Sounds a bit dodgy to me, I would not expect a 240V 13A fuse to carry 260A at 12V, I would expect it to go pop.
have you ever seen a van with a bad review?Somewhat worrying when the technical advice in a popular motorhome magazine contains misleading information.
That is what I thought, thank you for confirming it. Having divided the voltage by 4 he has wrongly multiplied the current by 4, which I find very worrying in a technical article.Its nonsense, the switch is rated at a maximum of 300A UP TO a maximum of 48vDC. It is still rated at 300A at 12vDC. All sorts of factors go into switch design and you cannot simply do an ohm's law multiplication. In fact Durite do a 550A version as well.
Yes, me too! Odd because most Tech magazine articles are vetted as they could make themselves liable giving incorrect information. The voltage classification gives what level of withstand the insulation of the switch is capable of, the current rating gives the ability of the metal conductors, contacts etc to carry the rated current. In this use neither voltage or current can be related using Ohm's law.That is what I thought, thank you for confirming it. Having divided the voltage by 4 he has wrongly multiplied the current by 4, which I find very worrying in a technical article.
