Is this a 12v tv
Autotrail cheyenne
newbie
I have seen this advertised in Aldi and wondered is it suitable for a motorhome.
Sorry newbie so not sure what the difference is between mh and caravan TV
Broken Link Removed
Broken Link Removed
A motorhome is a caravan. A Motorcaravan.
I'd be very surprised if it was mains only, the previous model was made by bauhn and was listed as having a 12v dc adapter. Seems like they've just left it out of the description this time.
I agree, the spec is very sparse and does not mention the power requirement.
Surely if it was either 12v or duel power they would have said???
Thanks. As a newbie and with nothing saying 12v I wondered if caravan had different points.
Best bet is go to the shop and see if it has a cigarette lighter plug on it. The box probably gives better info.
Yes, more spec here and states 12v
Connections:
  • Satellite connection
  • Antenna connection
  • 1 x USB
  • 1 x HDMI® with HDCP decryption
  • 1 x SCART
  • 1 x VGA (15 pin D-Sub)
  • AV In (adapter 3.5 mm jack to RCA)
  • YPbPr In (YUV) (Adapter 3.5 mm jack to RCA)
  • PC Audio In (3.5 mm jack)
  • Headphone jack (3.5 mm jack)
  • Digital Audio Out (SPDIF) (coaxial)
  • 12V DC mains connection
You will not be able to check in store, they are online order only.
Geoff
Connections:
  • 1 x USB
  • 1 x SCART
Thank you
Reactions: M-J
Broken Link Removed
I bought one and it comes with 12v cable
Medion are usually well made products. However, this one is not a SMART TV so all signals are by aerials/dishes. Bear that in mind against what you want to have access to watch. We've gone wholly WIFI with a MIFI aerial and data sim, reliable across UK and Europ and no trees to worry about (for sat dishes). Worth thinking it through before you buy.
Easy to add a firestick to it it has usb for power to the firestick. It’s a great tv for the price and a decent size 👍
