As close to your leisure battery as you can.
thanks are they normally very noisy?As close to your leisure battery as you can.
No, just a bit of noise when the fan cuts in if they are running at high power.thanks are they normally very noisy?
What size are you fitting & for what use?
Is that because of the size you say that?I hope you have a very large bank of batteries.
That doesn't make sense normally peak power is twice the continuous power and is best ignored as cheap inverters can never deliver it.Not sure if you can see photo. But it's a 1500/6000W Use for tv, satalite, hairdryer.
think it's modified sine waveWhich version have you bought how many watts?
Is it pure sine wave or modified sine wave?
Definitely wouldn't use it for TV or Sat receiver.think it's modified sine wave
Anything without sensitive electronics.What is it used for then?
does that mean tv's ?Anything without sensitive electronics.
Yes, some are OK but not worth the risk.does that mean tv's ?
which invertor would you recommend for tv, satalite, hairdryer.?Yes, some are OK but not worth the risk.
would the Victron 1 you mentioned be enough for a 24,inch tv and satellite?If you want a decent one probably Victron they have very low standby current. Their 1000va (800 watt) is about £350 bigger ones a lot more.
You can get cheap 1500 watt ones on ebay for under £200 but it's pot luck how good they are.
Way OTT for just those you probably only need about 150 - 200 watt.would the Victron 1 you mentioned be enough for a 24,inch tv and satellite?
I thought it was ott too. Think listened to too many people and got confused. I was going to buy a 500/600 watt. Will try and sell and get another 1.Way OTT for just those you probably only need about 150 - 200 watt.
Should say the power requirements on the units.
I can look tomorrow but think tv is a Hyundai 24 Inch not sure about satellite.What TV and sat box are you using?
Led TV 40 wattsWhat TV and sat box are you using?
So a 100 - 150 watt would do.Led TV 40 watts
Sky Box 25 watts
