Hello peeps,
I have purchased a Votronic 1700w inverter for various bits inthe van, mainly 2 x ebike batteries but occasional toaster and remoska use this is getting wired in to the 240v system by Roadpro in June along with a b2b and all the necessary extras, all good so far however I bought the inverter early so I could wire in to my battery bank (300ah lithium) and be able to charge the bike batteries via the inverter socket as we are away a few times before June. I have all the votronic recommended cables and 250A in line fuse so that will work fine then my light bulb moment last night, can I run my normal hookup cable from the inverter into the van hookup connection as if connecting to shoreside power, this should give me power to all van sockets not just the one in the garage (where inverter is located) will turn off the mains charger so not charging in a loop and also fridge and heating on to gas. I can't think of a reason for this not to work ok short term, only downside will be garage door slightly open to let cable out. Is there some reason not to do this ? Sorry for long winded post but thought it best to explain fully, @lennyhb or funflair and the many other electrical experts.
Thanks in advance
Thanks in advance
