inverter and ehu switch over (2 Viewers)
lee52
327
119
tyne and wear
selfbuild
newbie
hi guys and gals I have started the rewire of the ole bus hab electrics
I want to have an inverter so tv etc... can be used when wild camping and traveling. is the normal setup even when hooked up on site u would still use the inverter to run the v etc..(charging hab batteries from ehu) I know you can get auto switch over units so when you plug in to ehu it isolates the inverter or do u just have some sockets wired to inverter and some wired to ehu
Or is there an easier way ( the auto switch over units i have seen are v expensive marine shore power jobbies) Ideally would like a system where I dont have to be swapping plugs about etc...
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The 12 volt TV would be the best option, along with 12 volt chargers for laptop and phones.
If you must have an inverter for the microwave and hair straighteners then its best to have all sockets wired to the inverter. My RMB came with a pure sine wave inverter wired into the system with all sockets hotwired to the inverter. There is two remote switches that have to be thrown before the inverter will work.
The simplest solution was on my old Rockwood where after the hookup there was a double socket with a 3 pin plug, one for mains and one wired to the inverter. To use the inverter I had to physically take the 3 pin plug out of one socket and put it in the other. This way there was no chance of having the inverter wired up when on hookup.
haganap
12,760
26,461
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I have to agree that a 12v tv would be best.
However I have a inverter wired in to the sockets using a relay...
If you search for Techno100 and look at his posts, he has produced a very useful photographic diagramme of how to do this :thumb:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Have to agree with Haggers, Techno100 has posted some brilliant descriptive photographs of his set-up, if I find them I'll post the link.......:thumb:
Here it is.....
L
lee52
327
119
tyne and wear
selfbuild
newbie
so tv wise what tvs are 12v dont want to buy a "motorhome one" as with things of his nature as soon as you put mh in the title the price doubles lol
so what domestic tvs come with the external psu?
cheers Lee
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
Installed
Hi Techno while I very much appreciate all the excellent information provided by your good self on here being a simple civil engineer I find I do things much better if I have a drawing to work to even if it is a simple line diagram showing the components and their relationship to each other. I understand what you stated stated in a previous post about anyone with a sufficient level of competence being able to follow the information provided in your photographs but when going to carry out the work of installing panels,inverter and the kit they require at a location without power or internet connection I would very much appreciate having a diagram which I could print off to follow.
Thank you in anticipation
Ian:thumb::thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Hi Ian
I believe it is all in the original thread?
Try from here on my previous van
buckby
213
147
nottinghamshire
we bought an £80 tv from currys it is led and we have run it for two years up to now easy to put on a bracket as the box it came in was heavier than the telly if you look at them at currys just look on the back of the telly and it will say 12 volt input
May 7, 2013
845
1,353
RUK
Hi Ian
Hi again,
Could you please list the numbered components to avoid any confusion
Really really find your kind help invaluable
Ian:thumb::thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
They are the terminal numbers on the RS relay
Techno
Jul 28, 2010
15,475
20,756
May 2010
Just found this in my gallery
My relay installed on a Niesmann & Bischoff
Same set up as mine with 1800watt sterling
L
lee52
327
119
tyne and wear
selfbuild
newbie
Cheers techno100 such a simple and easy solution to what I was after its one of them things when when you see it, its a doh why didnt I think of it, lol
dahlia duo
Somerset
c class
What TV
:thumb:
cheers Lee
Dear Lee
Have just put a tv in van just before christmas Had a good look around before we bought, my main concerns were power consunption, cost, viewing angles, 12v to 240v and not 240v to 12v, free view.
so i purchased a british made 19" Cello Model No C19103f-led It has dvd hdmi port, scart,and others, great picture the power consunption is 15w and the cost was £160 the company sell on ebay. So thats one i would recommend.
good luck Mark
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
I must fit my inverter more permanently. Just a couple of minor questions you could answer from your experience with the installation.
You used a relay with a mains operated coil. Is it still operating quietly?
Did you have to derate the flange mounted relay when installing it in a small enclosure?
Many thanks IA
Techno
Jul 28, 2010
15,475
20,756
May 2010
It's very quiet.
No derating it is already potted anyway. If you go on the RS website the specification is provided. If suggesting it might get hot? no it doesn't
