Internal dimensions
Lunar Newstar 58L
Newb
Hi guys and gals,
looking to start my first pvc in the coming months, I have a good idea of everything I need or want internally but I’m going backwards and forwards with van choice so need some help.
i’m set on a rear fixed bed across the van, what are my options?
looking at Sevel range but auto box is high on my list, would a sprinter or crafter do?
Is there somewhere that lists all the important dimensions for reference?
Hi , sevel range will give you a 6ft across bed, whereas Sprinters, transit will not.
bed across means that you have more space towards front for kitchen/toilet etc.
you said fixed but think about folding or as we have a metal frame that just slides out in 10 seconds.
Of the Sevel vans, I believe only the Fiats offer the option of auto transmission
Sevel vans are the only ones that can accommodate a transverse bed long enough to be accepted by DVLA to be classified as a 'motor caravan' - that said, achieving this has become more difficult, worth doing a search on here
Dependent on the age of the van you are looking to purchase, earlier transits, mercs & vws are rust buckets - later ones are galvanised (who would have thought I bought a Peugeot instead of a merc of vw because of rust - but I did!)
In terms of accessories/conversion components they are generally more available for the Sevel vans than the others, as they are the most popular base van/chassis for moho manufactures
forget DVLA reclassifying van as Motorcaravan, at present no matter how close to their specs you convert Yours, they will only reclassify as Van with Windows ! Not that it makes much difference. They did say to me that because my bed was 6ft I can continue to use it as a motorcaravan, very good of them to let me.🤪
Ducato's are often the best option for PVC's, more layouts available due to the extra width. From around Sep last year a proper 9 speed auto is an option before that it was the Comformatic box which is pretty good (I'm on my 2nd van with it).
And Citroen Relays, if you are happy with manual box, the Citroen engine is better than the a Fiat IMHO and Citroen pricing is better usually.
Thanks for all the replys guys,
So could I fit a standard 190cm double mattress across a crafter? After insulation and paneling..
My understanding is that there are no recent panel vans that can have a standard domestic bed length fitted transversly. Such vans did exist in the past and I may be wrong about the current situation, but if there is one, it isn't a common one!
look at Ducato/boxerbRelay ( Seval vans) all will let you have a standard double bed 6ft by 4.6 transverse, which is what I have, very comfortable. Just measured it and it’s 72 ins from wall to wall with 4 seasons insulation.
No transit will give you the room and the Sprinter/ Crafter range are narrower too.
6ft is not the standard double bed length. Standard UK Double is 6'3" x 4'6" (190 x 135).
I stand corrected 👍🏻Does the extra 3 ins make the difference ?
less insulation then 😱
It does for me. I'm 6'2". You can't reduce insulation, as the maximum width is determined by the reinforcement ribs.
TBH, the 190x120 bed I've fitted in ours only works because it is longitudinal and my toes can poke out the end. At home, the bed is 200x150 (i.e. King Size), which works fine.
We have a swift mondial on a Peugeot boxer and we have a standard double mattress across the rear. We took it of a bed at home so we know it’s standard
I wonder if they removed the offending ribs and replaced with a lower profile reinforcement?
It is like this, but we have it permanently made up as a double bed. Our double mattress fits exactly!
View attachment 422756It is like this, but we have it permanently made up as a double bed. Our double mattress fits exactly!
Out of interest, what is the actual dimension wall to wall? Certainly from the pics, it looks like they've modified the walls to be thinner. The window certainly looks very low profile.
The Hymercar Grand Canyon is based on a Sprinter but they have modified the sides to accommodate a bulge for a longer bed...
They quote 6 foot by 4 foot 5 but the mattress fits perfectly
Shouldn’t have stood in the grow bag for so long 😉
