Intermitent engine cut out (1 Viewer)
TREES MOVING
HORNCHURCH, ESSEX
COACH BUILT
2 YEARS
Hi, I hope someone can help. I have a Roller Team T590 purchased new last year based on a Fiat Dicato 2.3 litre Euro 6 engine (manual). Ever since new the engine will cut out, intermitently, so that there is no acceleration. The engine goes into idle mode (800 revs/m). If I put my foot on the accelerator pedal, the revs do not rise. This idle mode can last anything from 10 seconds to a minute, after which the power returns. I returned the van to a main dealership in East London where on the second visit they said they had cured the fault telling me it was a faulty hill start switch. The problem remained and I now have taken the van to a Fiat dealership in Kent where they cannot identify the fault. The engine went into idle mode about 7 times on a short 15 mile joirney a couple of weeks back. As stated above, the fault is intermitent but seems to occur mostly when breaking or de-accelerating especially on hills. If anyone can shed some light on this it would be greatly appretiated.
John (TREES MOVING)
43,344
49,545
At first guess....
Intermittent Throttle pedal position sensor or associated wiring fault.
But it should throw a fault code in the OBD memory.
ambulancekidd
Sep 23, 2014
10,373
28,401
Ayrshire Scotland
Swift Kon-Tiki 640
Buy yourself an OBD2 reader & keep it plugged in whilst you drive, it'll give you the fault code when the intermittent fault occurs. The type that I think might suit you best is the permanent plug in one that uses your smart phone.
It is odd that the vehicle isn't storing the fault code
Something like this below.
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
dont know about the 2.3 engine but had a similar problem with my 2.2 relay, started with hesitation on accelerating and eventually cutting out but would always restart, gradualy got worse and had egr valve changed as had a code for it but still had problem which turned out to be the fuel pressure relief valve, my mechanic was running it and checking various perameters and noticed fuel pressure was fluctuating when just ticking over so new valve and all good once again
T
TREES MOVING
HORNCHURCH, ESSEX
COACH BUILT
2 YEARS
Thank you for your replies. I have found out what causing the engine to go into idle mode. If you put your foot on both the accelerator and brake pedals, the engine goes into idle mode for about 10 seconds if no pedals are touched. This happens with the faintest of touched. This is meant to happen and that is why a fault was not showing up. This in my opinion is potentially very dangerous and I need to know why FIAT thought that this was a good idea. I wanted this to be disengaged but the Dealer said this was impossible. I would welcome your comments.
43,344
49,545
Never heard of that before but I agree it could be potentially dangerous although left foot braking isn't something you would normally need to do in a van unless it was a full auto.
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
This is quite normal on modern vehicles
11,956
16,571
I'm trying to understand the circumstances under which you would have a foot or feet on both pedals at once? Other than an expert user with an autobox doing it of course.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Most vehicles built since about 2000 (fly by wire/canbus) do the same, likewise with the handbrake, it's a fail-safe in case your accelerator gets stuck or goes faulty.
53,496
150,316
Must admit can't understand why you would want to do it with a manual. I used to left foot brake in Automatic cars, but in the Ducato (Comformatic box) the peddle is so far over it's not practicle.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
Perhaps the OP is a race/rally driver from turbo lag days:p
Aug 18, 2014
23,812
133,966
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
which normally means it needs the brake light switch adjusted or replaced. Had it happen on my last car
43,344
49,545
If that's the case why did two separate main dealers not mention this.
Can't say I've notice on my 2015 Hyundai as my left foot braking days are a long distant memory of my youth.
Feb 21, 2016
4,920
29,617
Uk
Since 2017
Coz they know naff all about it probably? What’s new.
Louis
1,204
982
Anglesey
Found this out when bedding new brakes in for mot- kept foot on throttle and gently braking- engine cut out, Kia Sedona 3.0cdti 2006
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
You might want to dry the brakes out after going through a flood.
Although probably more relevant to drum brakes rather than the more common disc brakes on modern vehicles.
TerryL
6,189
8,193
North East
Low Profile
So has this explanation sorted out the OP's problem? From the way he was describing it there was an awful lot of left foot braking or is it still a matter of sensor switch adjustment?
11,956
16,571
Change of footwear might help :D.
