Insulation of water and waste tanks (1 Viewer)
Feb 26, 2023
41
8
Minera, Wrexham, UK
Bessacarr 445
I'm a newbie
Looking for information whether I can insulate my water and waste tanks please.
I bought an old 1999 fiat auto trailer last January and the main time I will use it will be autumn/winter time.
I am away at the moment and have got up this morning with frozen water tank is it possible to insulate them
Thanks in advance
Dec 24, 2014
9,255
47,797
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Unless you apply warmth to the tank it matters little how much insulation (cladding) you fit because the water temp will eventually drop to ambient. If any water supply pipes are external they will also freeze.
Are the tanks internal (e.g. in an inside locker) or underslung?
Do you have a large battery capacity and a method of charging them or are you on EHU?
D
Feb 26, 2023
41
8
Minera, Wrexham, UK
Bessacarr 445
I'm a newbie
Thanks for the prompt reply.
My tanks are under slung, I don’t have a large battery capacity but have solar panels fitted earlier this year , (300)
I am trying to stay away from EHU
I might be able to expand the area where the battery is but will need professional advice on that
Dec 24, 2014
9,255
47,797
Compass Navigator
I'm afraid I can't provide much additional help as I only motorhome in Gentlemen's temps.
Some 'winterised' m/homes (mainly from continental manufacturers) have heated tanks and internal piping but I think that without EHU you'd be hard pressed to electrically heat yours, especially since solar yield is generally poor in the UK at this time of year.
As you are no doubt aware freezing temps can cause damage to taps, filters and pumps and burst pipe fittings.
My simple yet inconvenient solution would be to drain down and use a day container kept inside the m/h. Failing that I'd winter in Southern Spain. ;)
Maybe someone has a better solution.
Oct 2, 2008
4,489
8,002
Salopia
Duro 6x6 Overlander
since 1968
Anything external will need electric heating pads and tape to stand a chance , insulation will help with efficiency
but will still require a pretty serious amount of energy . Pretty much any unit designed for sub zero conditions will have it all internal , and heated .
Lenny HB
53,698
151,002
On the coast in West Sussex
Hymer B678 DL
Can you get a housing around the tanks? German vans with underslung tanks have a housing around the tank with insulation and a feed from the blow air heating system, it works well.
Oct 9, 2019
4,977
17,386
Todmorden
Van conversion
FUNSTER in a PVC
Take a look on Amazon, I purchased a couple of Heater pads and had them stuck to the underside of the tanks then sticky foam sheet stuck to tanks and pipe foil wrap wrapped around the pipes. As others have said the insulation will only slow the temp drop down, the heater pads will keep the chill off the tanks. I don’t see a big draw on the batteries when the heater pads are switched on but then I don’t have a real way of checking that they are working as they are covered.
D
Feb 26, 2023
41
8
Minera, Wrexham, UK
Bessacarr 445
I'm a newbie
Thanks for that
haganap
12,779
26,691
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
you can buy and install heating elements and or use heat pads. the amp drain is minimal, and worth it, you would also need to lag it it depends if its the fresh or the waste that is concerning you most.
Mar 30, 2019
2,781
5,158
Cardiff, UK
Since 2016
Either use a 5 or 10litre container or for a more permanent solution you may be able to fit a second or replacement freshwater tank inside, ideally under a seat with a hot air pipe passing through.
The waste tank you can leave the drain tap open with a bucket underneath.
