ludo
This might be the best and simplest option. It's a normal 16 amp EHU plug that you would connect to the van end of the EHU cable but, unlike the standard plug, this one has a 220 volt outlet at the back of the plug. You would need to make up a trailing lead from the "continental" type outlet with a 220 volt 13 amp 3 pin socket at the other end. This would trail under the van to the other side or anywhere you want it.
For safety, fit an RCD in the trailing lead.
First photo shows the plug with black rubber entrance for the EHU cable.
Second photo shows socket end to plug into van.
Third photo shows "continental" socket for plugging in 220v trailing lead.
