Ignition key stuck in barrel! (1 Viewer)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
just won't come out! Tried all sorts of wiggling and jiggling manoeuvres, turning the wheel, etc but the bugger won't come out!
2005 fiat Ducato, on burstner elegance.
Not overly worried right now, can set alarm and immobiliser when we leave her ( on a site) and will get it looked at by an auto professional when we get back to uk next week, but short of squirting WD40 and waiting till tomorrow to try agin, any bright ideas?
Not gonna force it, rather risk and waiit than be stuck !!!
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
I had that happen on a Citroen we had and it was the barrel that had collapsed, they said it was quite common. Might be that .
Aug 27, 2009
19,789
23,084
Hertfordshire
40 years
If it is automatic then it could be something to do with the neutral key release. If it isn't then I have no idea..:)
mustaphapint
580
778
Worcestershire and Brittany
Just starting
https://www.motorhomefun.co.uk/forum/threads/ducato-ignition-switch.91494/
I had a similar problem with my 2006 Ducato.
It seems the lock and/or key wear. In my case the lock was worn and the key wouldn't let me engage the starter.
I stripped it down and in the end I reassembled it without the steering lock as it didn't look as though I could trust the locking mechanism not to engage when it shouldn't.
The above links may give you a bit more information.
R
Robert Clark
When you say the key is in the barrel do you mean...
Should have bought a (my) Carthago
Still not too late to pick up the Motorhome of your (and everyone else's) dreams
Just sayin
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Just sayin
I would - but the steering wheel is on the wrong side for me! Change it over and I'd buy it!
...... As soon as I've sold my house!
R
Robert Clark
Mr David
My steering wheel may be in the wrong side, but the ignition key slides smoothly in and out, like a 1970's porno movie
Oct 20, 2014
1,345
5,962
Hampshire
Adria Coral 680 SL
Since 2014
Had this happen on my Peugot and similarly it was the ignition barrel and needed a new one. Hope you get it fixed OK soon.
Oct 5, 2009
348
315
anglesey
Autotrail Delaware
Bit of a long shot but just make sure one of the front wheels are not jammed against a kerb or anything it can put feedback up the steering column and jam the lock.
Nov 18, 2011
11,862
43,305
Planet Earth
A van
Over 25 year's
Sounds like a worn barrel it should be OK but I would not remove the key as you might not get it back in had this happen to me and it cause me lots of problems
Leave it it till you get it shorted just emobilis your van
Bill
