- Jul 18, 2009
- 11,189
- 17,846
- HYMER B644
Until I saw the Price !
GEE
When did they got up !
GEE
C200 door mountWhat type and how much?
Had to look it up myself, they have gone up a bit used to be about £140.C200 door mount
Not sure how I would vent through the roof.Had to look it up myself, they have gone up a bit used to be about £140.
Personally I wouldn't use the door one.
I had the door one, the underfloor & and on my current van I converted the under floor one to a roof vent.
The roof vent is the best & no filters required. The underfloor is quite good, although filters are £25 each I refilled them myself for about £3.
Yes it is...but not Dentistry...What's a SOG .?
Guessing it's something to do with extraction
Why 2 SOG's do you have an en-suiteUntil I saw the Price !
GEE
I've needed a replacement fan for at least 3 years but still haven't got over the initial shock!
Motorhome and caravanWhy 2 SOG's do you have an en-suite
Depends on van layout. My loo is next the the wardrobe took the pipe in the double floor to the wardrobe then up through the cable trunking you only see the top few inches where it connects to the roof vent.Not sure how I would vent through the roof.
That is not going to work on the pongs you are making whereas a SOG does.I thought all non SOG cassettes vented underneath so all SOG does is increase f@rt power to outside for you. A couple of sheets of loo paper over the open flap keeps the pongs away for free and also keeps the bowl clean - is this too much information
I don't mind the smell of roses that I createThat is not going to work on the pongs you are making whereas a SOG does.
What's wrong with a 12v Computer fan?
The cassettes do vent from below but the SOG sucks the smells out in another direction. With a SOG fitted you can disable the under vent but that is another story.I thought all non SOG cassettes vented underneath so all SOG does is increase f@rt power to outside for you. A couple of sheets of loo paper over the open flap keeps the pongs away for free and also keeps the bowl clean - is this too much information
They only vent from below if the Thetford SOG equivalent is fitted. I changed my SOG from the normal pipe vent to make use of the Thetford vent.The cassettes do vent from below but the SOG sucks the smells out in another direction. With a SOG fitted you can disable the under vent but that is another story.
On my cassette the vent is opened when the cassette is inserted in the enclosure but it only vents into the enclosure. It is to stop the sealed cassette from exploding if you drive up a mountain. I have disabled it to prevent smells but only because the SOG provides a better release to outside.They only vent from below if the Thetford SOG equivalent is fitted. I changed my SOG from the normal pipe vent to make use of the Thetford vent.
Lenny's Modding the new Gin Palace
Did you mount the pump directly to the ply board or did you put it on any vibration damping? Did you put any damping under the ply? Now managed to get some soundproofing rubber under the ply, it has made it slightly quieter but not sure it was worth the hours groveling on the floor to do it.www.motorhomefun.co.uk
Have to disagree. You've probably never slept next to one with your bedroom window open woke up thinking someone was trying to choke me withThe roof vent is the best & no filters required.
