I Love My E & P Jacks (1 Viewer)
Jun 22, 2014
558
748
Great Totham
Another question ...what do the little arrows by the green centre dot/light signify? Sometimes there's one, sometimes two when the jacks are down and the green light in the middle is green (i take that as level if its green).
Cheers
Jul 29, 2013
9,071
18,551
Salisbury
Hymer B678DL A class
That tells you what side needs lifting until the dot in the center if fully green(y)
19,368
30,326
Yes what I kinda thought but the light is green and one little arrow is lit.
Is the automatic level set point set correctly, ie when you level it on "auto" does it go to level as checked with a spirit level? and yes the orange arrow tells you which button to press to get to level but only when using manual setting mode I guess.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I accept that two jacks are always deployed together, to avoid twisting the chassis. But does anyone know how that is achieved?
If raising one side of the vehicle, say, the rear ram could be supporting about twice as much weight as the front one. So what process ensures that each ram is extended by the same amount/at the same rate?
Jun 22, 2014
558
748
Great Totham
Me again ...I do get some movement (slight rocking) when the jacks are well extended and the wheels are off the ground. Front or back. Is this normal?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Quite some time since my jacks were fitted but I've now noticed corrosion.
My front pair seem fine and appear to be stainless steel inner and outer rams.
The rear pair are different in that the inner rams appear to be chromed steel rather than stainless and the chrome is blistering and flaking which will eventually damage the seals.
I've emailed SAP yesterday for advice but no reply as yet.
ceejayt
3,210
5,822
Stamford Bridge - Yorkshire
RS Elysian A Class
I have HPC Hydraulics and they seem to deploy differently from my previous E and P jacks on previous vehicle. I think E and P deploy front and then back (or the other easy around). The HPC Jacks deploy one side and then the other and it depends on what it needs to correct.
Let's say standing in the van looking at the front and it is clear that the left side needs to be raised up. In this case, the right hand jacks deploy first just as far as touching the ground - then the left hand side jacks - this means that the left side jacks are not bearing the full weight and the right side jacks go back in slightly as required.
Only after that, with all four jacks deployed does it then switch to level front to back.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Have you been spraying them with lube frequently?
A good squirt of silicone spray every couple of weeks is advised.
Richard.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Richard.
Thats not the point I'm making really. They are not the same specification. The front are fine the rears corroded because they are not Stainless but chrome.
Jun 22, 2014
558
748
Great Totham
mine are E&P and have corrosion. Be intereseted to see what SAP say. Cant see they would have different spec'd jacks. Oddly though I think my rears are the ones suffereing corrosion. I'll have a look in the morning.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The fronts and rears are different units having different brackets. Maybe a different production run
Apr 9, 2018
8,643
44,670
Worcestershire
Bailey Adamo 75-4t
March 2018
Interesting thread. I reckon manually extending all jacks to max and spraying with GT85, or even better ACF50, every now and then would be a good idea?
Techno
Jul 28, 2010
15,475
20,756
May 2010
The very end of the ram is just painted steel so expect rust. The ram itself is the concern. My fronts are like brand new whilst the rears are clearly not stainless steel.
I would add that the silicon spray is for the benefit of the seals, inert so it won't attack them but lubricate. The supposed stainless steel does not need anti corrosion assistance.
5,070
5,973
West Yorkshire
My rears are corroded slightly, will drop them all tomorrow and report back.
Jul 29, 2019
13
13
bailey autograph 745
since 2016
Had mine for about 2yrs now and putting the rams down is the first thing I do. The missus was very anti due to the cost however now she absolutely loves them. Use them when the moho is in storage to take some of the weight off the tyres. In my mind best investment yet. Now to convince her that we need the air suspension, probably have to wait for the lottery result.
Oct 14, 2019
66
79
Chausson 640
Since 2019
Just had E& P system installed by Rosmia in West Sussex. Mat was brilliant. On site they are brilliant and van is so much more stable especially when we have grandkids with us as they are not the lightest on their feet lol. The only downside is my drive is too steep to use them? Would not be without them now.
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is a front leg and both rams have machining marks so definitely turned from solid stainless. No corrosion at over 4 yrs old
This is a rear leg and the primary ram is machined stainless with no corrosion but the inner or secondary ram is chromed steel and corroding.
Sep 28, 2015
2,018
2,615
Hymer B544
2001 Caravans 2011 Motorhomes
