I’ve had a solar panel fitted by local dealer to a chausson 610 (2 Viewers)
Feb 23, 2020
19
8
Chausson 610
10 years
The solar panel appears to have been wired directly to the leisure battery. Is this correct as the vehicle has. Been left in storage on mains power charge ,but the leisure battery is flat. This never happened before the solar panel was fitted has this cause the battery to flatten , if so where should the panel have been wired to the system as there is no indication of this in the manual .
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
I’m not sure , but there will someone who knows (y)
AndyPK
5,016
13,932
Cirencester
None……..!
Motorhoming since 2015......
If your ‘van was in storage on electric hook up, the leisure and vehicle batteries should have been charge maintained (if you have a B2B fitted), so has the leisure battery been left disconnected by the solar installer and is ONLY being charged by the panel…..or a blown fuse perhaps? :unsure:
Yerfdog
Feb 23, 2020
19
8
Chausson 610
10 years
I have taken the van out of storage, the panel started. Working ,which in turn put power to the control panel in the van .
It showed that the leisure battery was full . But it was very low .
Emmit
8,038
17,758
Pilote Explorateur
Jan.2014
"I have taken the van out of storage, the panel started."
Could I ask, Is the storage undercover?
stevewagner
1,825
4,058
Pevensey Bay
Yonks
A B2B is for rapid charging of leisure batteries via the cab battery. I don't believe it has anything to do with the on-board charger.
two
Aug 4, 2011
4,906
4,577
West Midlands
A-Class Fiat
To get the best support, please read your posts a couple of times before sending.
I'd love to help but don't understand what's going on and might even provide duff advice.
AXO66
762
4,715
Pembrokeshire
Chasson 510
Our Chausson CBE panel always shows a “full” battery when the panel is seeing any light. Have come to the conclusion it’s showing there is electric going in, nothing to do with the battery state. Best time to check battery is midnight, when usually we have 2 or 3 green lights .
Yerfdog
Feb 23, 2020
19
8
Chausson 610
10 years
Yes it’s a closed barn without windows so ,insufficient light to activate the panel.
Emmit
8,038
17,758
Pilote Explorateur
Jan.2014
Here's a pure guess.
The fitter of the solar panel has disconnected the supply of charge from the inbuilt charger to the batteries.
At the same time and because he/she did not disconnect the batteries from the electrics on the van, there was either a parasitic leakage or possibly known use of the battery to supply 'stuff' on the van.
Because your van was under cover, the solar couldn't do its job but started to do so once you took it outside.
Over to someone who knows what they are talking about.
That's my take on your problem
There's a fuse? missing somewhere.
