Northernraider
- Jul 30, 2017
- 27,417
- 177,419
- Mobilvetta eurayacht
- On and off since 95
Ok so I replaced my hybrid bike at the end of last year with a more robust mountain bike I bought from gum tree, it's a carrera model and is quite good for a second hand bike. It's done me ok up till now with no problems given I'm not a diehard cyclist and I'm only on it once in a while so it spends most of its life on the rear bike carrier.
I took it off a few days ago and the wheels would not turn .....the brakes were locked on solid.
Now this is the first bike I've ever had with disc brakes and despite being reasonably good with vehicle mechanics I never even gave the braking system on the bike a second glance when I bought it .....but it looks like it has hydraulic brakes which surprised me. So there was no way to adjust the brakes off that I could see but they were jammed solid.
Anyway I loosened the bolt where what I thought was a cable off and that's when I realised it was a hydraulic tube when a little fluid came out .....but this seemed to free of the brakes so by accident I solved the problem
I did the same to the back wheel and great stuff...brakes free again and actually working better than they had before.
No sticking etc after being used.
Anyway I was out for a ride etc and no probs came back put bike back on the rack and I've not looked at it since.
Took it off today to fit a handlebar height extension and the brakes were jammed on again.
So I did the same again and they free off.
But why are they jamming on ?
If I keep releasing the pipe and letting a spot of fluid escape there will end up with none.
The brake pads don't seem to be seized or anything as after I've slackened the pipe and tightened up again the brakes will work no probs ...
Any ideas?
Could it be the sun ?
I've had a couple of spells of rain here and there but these bikes should be able to cope with that without brakes seizing etc right?
I'm confused
And also where do you top up brake fluid and is it the same stuff as a car?
I
Any ideas?
I'm confused
I
