Hello @Guyadria.. interested in the Powcan but your link does not say anything about needing to be plugged into OBD2 port..
Just into 12v supply.
Surely any thief who gets access into your (unoccupied) van can access the OBD2 port by removing 2 screws in the knee panel in the dash … I can’t see how hanving a HUD plugged into the OBD2 port will not suddenly make your van more vulnerable..avoid the OBD plug in ones, as these are a security risk giving access to the port for thieves.
you can buy OBD port locks and relocation kits. The issue is simple, thieves can buy devices that plug in the OBD port that disables the various immobiliser security and drive your vehicle away without a coded key. They can also buy a device that reads the physical lock and mimics a key within seconds. If you have a typical alarm, opening the lock turns off the alarmSurely any thief who gets access into your (unoccupied) van can access the OBD2 port by removing 2 screws in the knee panel in the dash … I can’t see how hanving a HUD plugged into the OBD2 port will not suddenly make your van more vulnerable..
unless i have missed some security weakness…. If so, can you please enlighten?
thanks
So as I said, the vulnerability is nothing to do with an OBD2 HUD, rather any vehicle with a standard OBD2 Port...you can buy OBD port locks and relocation kits. The issue is simple, thieves can buy devices that plug in the OBD port that disables the various immobiliser security and drive your vehicle away without a coded key. They can also buy a device that reads the physical lock and mimics a key within seconds. If you have a typical alarm, opening the lock turns off the alarm
The value of motorhomes makes them a bigger target than a normal van and plenty get stolen each year. So yes, locking the OBD port is essential
all the projected ones I have seen are pretty useless in sunlight. The HUD developed for fighter pilots works well because of treated, non reflective acrylic canopies and the colours used. The cheap Chinese version relies on a small screen reflecting onto the windscreen, not a projectorDoes anyone have feedback on the HUD modules that project onto to the windscreen and how useful they are? I've had a look at the Powcan per the Amazon link which looks good but it would be a similar place to where i'd have a satnav and I'm wondering if the projected image on to the windscreen is better to be in my line of vision?
Nick
Oki doki... anybody know where I can get a cheap fighter jet to convert to a moho???The HUD developed for fighter pilots works well because of treated, non reflective acrylic canopies and the colours used
