tranby
Does anyone know the procedure to remove the cassette off a side window ?
The OP has been a Funster since 2015.
I see your a long time member but only posted twice so a welcome to posting might be appropriateDoes anyone know the procedure to remove the cassette off a side window ?
I just looked at their amount of posts...The OP has been a Funster since 2015.![]()
Hi SasboIf it's on a Fiat Ducato and is the Remis blind that retracts into the rear of the door then:
Remove the Remis Badged cap on the top rear corner of the blind. Then remove the self tapping screw securing the blind to the door.
Check if there is a self tapping screw securing the base of the blind to the door around the midpoint. If so remove.
Push up the blind frame at the rear of the door and this removes it from the securing bobbin attached to the door frame.
Pull out the two spring clip fittings that fix the front of the blind frame to the door frame adjacent to the A pillar.
Gently pull the middle black blind frame away from the door window frame to release the velcro strips and the Remis blind should now be free to remove.
Reinstallation is the reverse if the above.
Hope this helps
Just found this old post of yours which probably is the answer I was looking forIf it's on a Fiat Ducato and is the Remis blind that retracts into the rear of the door then:
Hope this helps
Me too, just waiting for the new wing mirror to arrive, thanks SasboJust followed Sasbo guidance to remove the Remis blind from the right hand cab window - works great.
Thanks![]()
Hope this helps
Similar to 1967bowesj I had the same issue on a previous motorhome and rather than moving the clip to the next fold I repaired the top of the blind that was torn using masking tape on each side of the blind pleat and then punched the correct sized hole in the repair to allow the blind to pass smoothly over the boss at the end of the top rail.
It's best to use the masking tape repair to the first three blind pleats as a precaution to stop the problem occurring in the future as the Remis blind is a fairly fragile bit of kit.
You will need to remove the entire blind from the door and then carefully remove the plastic top rail to do the repair. Take photos as you disassemble so you have a reference for putting it back together and don't loose the small screws that hold the plastic top rail in place. Don't ask how I know this![]()
Probably only paid once in 2015 and not paid since .I just looked at their amount of posts...![]()
