- Apr 13, 2012
- 6,011
- 20,697
- Mobilvetta Euroyacht
- 1996, then break 'til 2011
I went to unlock my hab door on my Mobilvetta to find the barrel of the lock loose - it just came out with the key.
Someone had tried (and probably succeeded) to get in. With the lock barrel out all you need is a screwdriver - it opens even if 'locked' on the inside.
The barrel is just an inch long and the same as fitted to the lockers - not good enough.
I am in the process of fitting a deadlock below the existing. I was going to reinforce the door anyway but was surprised at how flimsy the door was. Aluminium sheet on the outside of course but laminate covered ply no thicker than 3mm on the inside and 25mm of polystyrene between.
Before I decided to fit a deadlock I considered just replacing the old barrel until I looked on YouTube to see a demonstration of how to remove the barrel using just a steak knife.
