10.416 amps plus loses..... Around 11.5 amps total per 6 minutes at 10% loss
11.462 amps per 6 minutes assuming 10% inverter loses.Just to clarify, that's 11.5 Ah.
Watts divided by volts equals amps.
OK, If you want to be pedantic.11.462 Amp Hours, of battery capacity per each 6 minutes of use.
No, it uses 11.462 Amp Hours in 6 minutes.But It still uses 11.462 amps in 6 minutes
OldWomble ...... Every time you make a coffee it will discharge your battery by 11.462 amps.
That's 11.462 amps less than you had before you made a coffee.
Only pedants confuse things with amp hour etc.
Now go back and read the OP.The battery capacity is marked in amp hours. How is that confusing things?
What would be confusing (!) is if the OP wired up his inverter with cable to support the 11 amps you told him it would draw and set fire to his van.
The pedant comments aren't really necessary, a simple yes, you're right would have sufficed.
The OP will drain 11.462 ampshow much will I drain my battery?
He will not drain 114..62 amps in 6 minutes though 114.62 amps hour will pass through the wiring for 6 minutes.
Hey guys, please don’t fall out over it,
The current flow will be 114.62 amps for 6 minutes. 6 minutes is 1/10 hour. Battery capacity used (amp-hours) will be amps x hours, ie 114.62 x 1/10 = 11.462 amp-hours.The OP will drain 11.462 amps
