Hot water (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Hi, I can't seem to get hot water when I'm NOT on electric hook up.
What am I doing wrong ??
Which settings do I need please ??
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
I,ve had ultrastore on and the temperature on 70 for two hours and the water is still cold !!!
Think I may have a problem :(
522
1,228
West Cornwall
13 Years, 20 years with a caravan
Is there a green light on your ultrastore showing that you have gas and it has ignited.
Phil.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Yes green light is on, can't see a micro switch !!!
It's fitted to a elddis sunstyle gt 140
Cover is removed as we are using cooker with no problems
522
1,228
West Cornwall
Try altering the heat setting and listen to hear if the gas fires up. Also if your hot water tank is not full the thermal cutout would have kicked in may be auto resetting or may need manual reset.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Can't seem to hear the gas tripping in or out !!!
How should I do a reset on it ??
As my manuals are at home :(
522
1,228
West Cornwall
It should be an auto reset. Switch off the heater leave for a few minutes then switch back on. While switched off run the hot tap for a few seconds just to ensure flow into the heater.
If your green light is on then that shows that the pilot light is on with gas flow.
ambulancekidd
Sep 23, 2014
10,371
28,400
Ayrshire Scotland
Swift Kon-Tiki 640
There will be a gas manifold somewhere in the van. Its ridiculously easy to turn the supply off without meaning to. That's where I would begin my checks.
Good luck..Robert.
2,472
8,630
Cumbria
Burstner Solano t725
since 2014
We have an Ultrastore and had the same problem until we removed this cover from the outside of the MH..
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
As Boyce said above :)
The system had drained down and cut the system out !!!
Pulled water through turned the ultra store off then back on, heard the gas tripping in and out then left it for 30 mins then I had red hot water ;)
