Hosepipe connectors abroad (1 Viewer)
wanderwolf
7
west midlands
fiat bessacarr
newbie
Hi,
Please can anyone tell us where we can get a push on hosepipe connector for a tap which is larger than the standard 1/2”
We are going to Spain in April and know we will be at one site where they do not have a regular threaded tap for water. (Sitges). The tap is larger than normal and the only push on adapters I can find are for our standard 1/2” taps in the uk.
Many thanks
Julie
Mar 11, 2013
1,280
1,678
Gillingham
coachbuilt
since 2005
Check out poundland in the garden hose connection section.
W
wanderwolf
7
west midlands
fiat bessacarr
newbie
Can’t find anything on Amazon other than the standard 1/2”. Will take a look in Poundland though thanks
Aug 2, 2017
175
199
Worcestershire
Burstner Ixeo It 724
Since 2015
Both Amazon & Ebay have got 3/4" and 1" & Universal connectors listed - Just seen them but I haven't got the skills to copy the relevant pages.
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Go to a local ferreteria they’ll have what you need for a couple of euros ...(y)
Oct 12, 2009
10,661
23,651
A Class N+B Arto 69GL
Since 2009
If you mean the push-on type with a screw jubilee-type clip to tighten, then most garden centres would sell them I think. I cannot remember where we got ours.
Geoff
Dec 12, 2010
5,411
21,562
Cumbria
since 2011
The Range keep this lot in stock for £6.99. I appreciate you won't need all the other gubbins, but the bit on the right fits 1/2" & 3/4" threaded taps.
Aug 22, 2017
829
1,946
Wildax Europa PVC
Since 2014 -- cycle-camper before that
Hozelock do 18mm and 24mm push-on connectors that they call 'mixer tap connectors'. You can get these from various places like Screwfix, garden centres -- the Hozelock name adds a few quid to the price though! As already suggested it's cheaper to get the 1 inch and 3/4 inch push-on connectors from ebay.
Jul 5, 2013
11,726
13,705
Since 2013
There are three standard sized threads that are used in the UK and Europe. 1/2", 3/4" and 1". The "normal", i.e. most common one is the 3/4" one which, in the UK, is usually fitted to taps with a 12mm copper supply pipe. I have not seen any tap larger than the 1" sized ones.
If you look at the post #11 above the fitting on the right of the photo has a 3/4" thread with an adaptor screwed in to fit a 1/2" thread. You can get a similar arrangement, only with all 3 of the standard sizes, from B&Q. It is called a You can also get them from Ebay. Just search for tap connector and you can get a 1" one or a 3 in one like the B&Q one. They seem more expensive though.
I suggest you may want to buy at least a couple. I regularly leave mine on taps!
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
I have a Hozelock 3 in 1 adapter, it’s a one inch adapter with two screw in pieces to convert to 3/4 and 1/2. I’ve needed all three sizes on our tour of France Spain and Portugal.
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Just buy when there.
Any French or Spanish DIY store has shelf loads of all the possible different adaptors you could imagine.
Minxy
32,651
66,541
E Yorks
Carthago Compactline
I had this problem in Germany I used the Acme thingmebobdoodahwhatsit universal adaptor. Hard to come by but I have a few spare at £9.99
I'm not gonna ask exactly what 'rubber tube' you've used but ... do you have one big enough for this .... ? :D The water comes out of lots of little holes along the front pipe ... :rolleyes:
Sep 12, 2016
2,267
5,038
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
You're going to Spain - - - Easy almost EVERYWHERE we have been in Spain there are Chinese Supermarkets ( Court Chino / Marche Chino ) they sell EVERYTHING you will need except food
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you need 1/2 3/4 and inch threaded adaptors a male to male hozelock and a rubber push on with a jubilee clips this will cover everything your likley to come across
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
One thing worth having in your connector box is a double male hozelock connector. The French in particular like to use these with a water stop socket on the stand pipe to stop you leaving the tap on
Minxy
32,651
66,541
E Yorks
Don't forget a multi-tool too so that when you find a tap with it's top broken you can still turn it on/off with the pliers bit.
Minxy
32,651
66,541
E Yorks
THAT`s where the condoms went!:D2:whistle:
Well I suppose he hasn't got much use for them for anything else nowadays ... :ROFLMAO:
Aug 18, 2011
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
We Tend to use a 10 litre watering can its usually the simplest and most social as you can have a chat along the way.
Same here,,gave up the hose a couple of years ago..Lets face it we all have plenty of time when away in the van,,BUSBY..
