Hook up Cables. (1 Viewer)
swiftsteve
320
803
kent
Adria Coral S 680 ST
Since 2008, with a gap between 2013 and 2018.
Hi all, I've just bought a cable winder as my cable is becoming a bit twisted just winding it around my elbow.
As I fitted my cable to it I noticed a tag with a date on it (week 36, 2016). So how often should we renew our cables?
I just bought a new 10m one on ebay, as my 25m cable is far too long for everywhere I've been so far, which I think contributes to the twisting.
Oct 16, 2018
638
1,648
CHESTERFIELD DERBYSHIRE
PILOTE
Long enough
I've been using mine for at least ten years and unless yours has any damage I don't see why you need to worry about the date on the cable.
I am not a qualified electrician.
:france::france::france::france:
Gellyneck
8,997
17,659
Scotland
More than toes wet now!
You should never winds a cable around your elbow as you've found out.
You should use a method which removes the twist as you coil it up. A cable winder will work.
I cut my 25m cable at 10 m and fitted new ends
So I now have a 10m, a 15m and still a 25m :D
With no extra weight
Assuming your in-line connectors are properly IP rated. Don't think the standard "blue" socket \ plug are.
swiftsteve
swiftsteve
320
803
kent
Not a bad idea, how much were the ends?
Jan 19, 2014
9,038
23,592
Derbyshire
Elddis Accordo 105
since 2014
I wouldn't bother, you're only introducing possible points of failure, points for rain to get in and people to unplug. 25m is hardly enormous is it :cool:
Also with a one piece ehu cable, if your van socket is in a locker you can use the cable as a security loop against opportunist thieves. Simply run it through your table and chairs and you have an electrified anti theft device (y)
PS and if you want to save weight downgrade it to a 1.5mm cable :eek: :whistle:
Lenny HB
50,273
138,871
On the coast in West Sussex
Hymer B678 DL
You are winding them incorrectly if they are getting a twist in them. I don't use EHU very often but when I have 25m is hardly ever long enough, so if I think Igoing to use EHU I carry 2 cables.
Nov 4, 2014
1,407
1,005
blackpool
Just looking
I was at bury campsite.i had left my 2j5 my at home.so connected 2x10 mt together. Was told not allowed. Move to another pitch nearer a bollards that is closer to van.
May 7, 2016
6,635
10,401
West Sussex
Carthago Compactline
Since 2003
A cable winder is the easiest answer. However, there are two ways of coiling a cable safely. The techies way works if you want all the coils to drop out without a twist whilst holding both ends. I prefer the mariners rope coiling method which works better if, like me, you drop the coiled cable on the ground and pull from one end only, usually as I walk away from the coil. It also works better if you want to hold one end and throw the coiled cable towards the hook up.
Aug 6, 2013
11,843
16,243
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
No it's not.
They are IP rated. Their rating allows for water splashes and rain but not direct jets of water or submersion. If plugged out in the open they must be held above any possibility of submersion. The objection on some Club sites to plugs / sockets in the open is that small humans might fiddle with them. They're rated IP44.
http://www.dsmt.com/resources/ip-rating-chart/
Lenny HB
50,273
138,871
Hymer B678 DL
That's just common sense nothing illegal or dangerous if used correctly.
Fletton
1,531
4,242
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
And what’s to stop small humans “fiddling” at the post - I wonder!?...
Edit: a live end if joined ;) silly me but they’d have to stick a bbq rod int ole..
ctc
Oct 12, 2015
1,430
2,356
Crowle
Hymer b680
New
Far too much fuss is made about so called "safety" with electrics. Plenty of sites have a poor earth, poor connections at the posts and our motorhomes are fitted with MCBs and RCDs, both unreliable. The safest protection was the old fashioned fuse wire, you could see it. Electric shocks can be painful and more than one very annoying, but you are far more likely to be killed driving your pride and joy than plugging it in.
Jan 28, 2008
9,955
17,664
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
which club site is that?
May 7, 2016
6,635
10,401
West Sussex
Since 2003
I would rather put my trust in a 30mA RCD that trips in 30 to 50 milliseconds than a burning 3A fuse wire, bearing in mind 100 to 200mA is considered potentially lethal.
Gellyneck
8,997
17,659
Scotland
No it's not.
I will stand corrected then!
I understood that IP44 only protects against splashed water and therefore unsuitable for exposed external connections, eg where the connection could be in standing water.
Jan 19, 2014
9,038
23,592
Derbyshire
Elddis Accordo 105
since 2014
Isn't anybody going to mention my potentially lethal 1.5mm hook up lead? We could die at any point and you're all chatting about plugs and RCDs :cry:
