hook up box (2 Viewers)
Bruce
147
51
Glasgow
AUTOSLEEPER FLAIR
TWO YEARS
Hi just received hook up box but no instructions and have a couple of questions. The box has a rubbery foam type of gasket ,does this go inside van with silicon outside or does this simply act as a gasket between van and box. Also no marks inside box to indicate wiring i e live and neutral. Any help......Bruce
PS Can I use normal house 2.5 cable to the RCD
4,924
11,290
Flintshire
Low profile
since 2010
I was recommended not to use house wire, it's single strand and not very flexible against vibration, you need multi strand cable.
Gasket between plastic and van body. Possibly better to bed it down on a good mastic, depends how good the foam looks.
If you mean mains twin and earth, bad move in a vibrating vehicle, use good quality flexible.
Bruce
Bruce
147
51
Glasgow
AUTOSLEEPER FLAIR
TWO YEARS
Thank you for advice, any idea for wiring this up please also whats the plastic springy thing inside box for...Bruce
8,165
11,230
Yr Wyddgrug
Hymer B678DL
Plastic springy thing is to allow you to release external plug. That is if I understand what bit you mean.
11,932
9,097
2,355
10,235
16th Edition IEE Regulations
This is a very useful guide for Caravan Electrical Installations.. (same as motorhome)
http://www.tlc-direct.co.uk/Book/7.9.2.htm
If in any doubt about any aspect of your installation consult a qualified electrician... don't make educated guesses.. getting it wrong can be fatal.. in more ways than one.
