ShiftZZ
Wow how much did that lot cost? How many years before you get your money back.
But the wind usually drops at night.Wind turbines work at night.
But, don't forget to trip your breaker before using itHONDA EU22I 2.2KW/2.2KVA PETROL INVERTER GENERATOR | Generator Direct
The super-portable Honda EU22i will deliver a max 2200W of clean mains quality electricity to run and rechargegenerator-direct.co.uk
Guaranteed power, 24/7 at the flick of a switch!
Its almost like magic
Plug into your house, when the lights go out, they come straight back on!
Sniffy won't buy one he is Welsh! To him it will be wizardry!But, don't forget to trip your breaker before using it
Get a Tossla Powerwall. You know it make senseThinking about it... Would the following work..
4 x 100A 12v batteries wired in parallel , fed by 240 mains, plus a solar panel and possibly a wind turbine, I suspect two controllers?
Output via a 1kw inverter..
I use the victron 3kw all on one, super simple to use, comes with the colour GX included so I can check and control the system remotely, this is nowFor a house storage system, you could use a Victron Multiplus inverter/charger - there is a 1kW model - and 4 x 100Ah batteries. They are used without solar to provide backup for power failures, or to store power from cheaper times to use at peak times.
A Victron SmartSolar controller would integrate perfectly with that setup. You could add a ColourGX panel to view/control everything, or use a VenusGX box with a Smartphone App.
If you're only powering the inverter from the batteries, you could consider 24V or 48V.
The PylonTech batteries suggested by Tykatem integrate very well with Victron systems.
I is a poor pensioner, spend my winter fuel allowance on England winning the Grand Slam..Or buy a generator and everything works
