Hi Everyone, Newbie in need of hep with a step issue please (1 Viewer)
Bobfox
3
A Class Adria i707SG
Im a newbie
Total newbies here
Picked up our Adria I707 last week from a dealer, spent a week trying to work out how everything went together and worked along with a few heated discussions with the dealer who seemed to blame everything on others and COVID. I know its aging but we still paid a lot of money for it
Went away this weekend to Stourport to try it out, we had a lovely few days and most things worked OK but there seems to be one really worrying issue. The step although retracted before we left and double checked, when we arrived there and back home it was extended.
Can anyone help please?
Jun 29, 2015
3,477
57,413
Southampton
caravan (for now)
on and off since 1984
Does it have an alarm? Most have a buzzer to warn if it is out
Nov 13, 2012
440
438
Somerset
coachbuilt
since 2000
Is the step locked out or can you push it in by hand
suavecarve
7,551
38,954
Surrey/Hants
Rollerteam 685
July 09
Did it "used" to come in when you turned the engine on and bleep as you did it and now it doesnt ?
If that is the case then the relay is a good bet.
You ll need to provide model and age for someone to identify where it is (underneath the van where it can pick up gunk would be a good guess)
reperable in the first instance by use of wd40 and luck, in the second instance a new relay which can cost up to a ton or a 2 bottles of cheap wine for a PHD student studying electronic engineering in my case, then sealing it better than the manufacturer
Feb 21, 2016
4,920
29,532
Uk
C class
Since 2017
Steps are a pia. Glad I havenā€™t got one.
B
Bobfox
3
Im a newbie
Thank you for your welcome
On the step issue
No there is no alarm
I havenā€™t tried to see if it comes back in when the ignition is on I have just used the switch by the door to retract it before driving off
Am I missing something
Where is the relay, near the unit or somewhere else?
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Does it work at all now?
Some had a weak actuating shaft that snapped. Once broken, they don't work at all and need replacing.
Replacement is pretty simple.
Sep 10, 2019
3,358
1,613
Warwickshire
Hymer camp c546
Since 2019
Hi and welcome šŸ˜„, to be honest we purchased our hymer 2003 last summer..after reading about electric steps ..this and that happening with them..ours worked well and yes our buzzer goes off, if left out ..but we decided on having a 2 step of our own, don't use our electric step...but put it out every now and then, just to keep mechanics moving, yes sounds pointless..but had my knee replaced and happier with our own height of step...suits better..good luck. (y)
B
Bobfox
3
Im a newbie
As I discovered this morning on my way to the garage to have other bits fixed the step comes out when the ignition is turned on and it wont retract on the internal switch but if I turn off the ignition and use the internal switch it will go both ways in and out
Vic. Parsons.
415
1,970
Wales
Hymermobil S740
since 2014
Sounds like it's been wired up ass about face if it's going out with the ignition on.
The dealer should correct it for you because it's both dangerous and likely to cause extensive damage if you hit a curb.
