Hi - Ducato import from France- help needed... (2 Viewers)
gvj
gvj
Dec 1, 2020
19
18
Hi top Ducato
2 years
Under 3500kg £270
Over 3500kg £165
That’s what I thought, but I couldn’t understand why a camper under 3500kg should cost more to tax than a one over that weight. Is there some bizarre logic here that I’m missing or is it just some weird UK anomaly ??
53,482
150,239
Over 3500 VED is the same as a goods vehicle it has been £165 for about 15 years its not subject to annual increases.
I don't know why but I'm not complaining about it.
gvj
gvj
Dec 1, 2020
19
18
Hi top Ducato
2 years
874FA06E-84CC-4D2F-8AF0-E39A153FB844.jpeg Another newby question....Sorry to be a bit dim here but on the identification plate the figure under the serial number reads 3.300 kg and the one below that 5.800 kg. Is it the former that the DVLA use to decide the duty ? What’s the second one - fully laden weight or ???
53,482
150,239
3300kg is the MAM (Gross weight) this is the one for VED
5800kg is the Gross train weight - vehicle gross + trailer.
1750kg max front axle
1900kg max rear axle
53,482
150,239
With a gross of 3300kg you may be very tight on payload should be uprate to 3500 or 3650kg without any mods. For 3650 you will need a C1 licence.
gvj
gvj
Dec 1, 2020
19
18
Hi top Ducato
2 years
Thanks again Lenny. This is our first camper so err, when you say “uprate” are you talking about beefing up the van in someway or ??
53,482
150,239
I said without any mods, your total axle weight is 3650 so you could go up to that.
Best to weight the axles on a weighbridge when you are fully loaded for a trip. No point in uprating of the axles are on the limit. Even then the rear axle can normally be uprated.
