- Jul 18, 2009
- 11,275
- 18,219
- HYMER B644
It was fully charged on Weds via EHU.How long ago was the battery fully charged? It's showing around 50% now does that tally to your usage?
What you say is valid, but in his screenshot the state is “Off”, so it’s not activated charging at all yet.I've found that if the current levels are below a few watts, my Victron gear can still see the flow, but the FogStar BMS rounds it to zero.
So could be it that the solar is pushing in an amp, but with other parasitic loads, not much reaches the battery and the FogStar is calling it nil?
Isn't that for the switchable load terminals that nobody uses?What you say is valid, but in his screenshot the state is “Off”, so it’s not activated charging at all yet.
No, it’s for the actual charging. You find loads of threads on the Victron community site.Isn't that for the switchable load terminals that nobody uses?
I thought it referred to these.No, it’s for the actual charging. You find loads of threads on the Victron community site.
Are we looking at the same pictures? I see the solar charger producing few wats, all good, and bms charging enabled, wether that charge makes it to battery or local loads needs measuring. The bms can not see small currents, it does not have a shunt, it measures by a Hall effect sensor that’s inaccurate below 2 amps and no detection under 0.2A.What you say is valid, but in his screenshot the state is “Off”, so it’s not activated charging at all yet.
All correct but look at the State on the VC status screen ... it's Off.Are we looking at the same pictures? I see the solar charger producing few wats, all good, and bms charging enabled, wether that charge makes it to battery or local loads needs measuring. The bms can not see small currents, it does not have a shunt, it measures by a Hall effect sensor that’s inaccurate below 2 amps and no detection under 0.2A.
All looks good to me, besides of lack of solar panel output.
I see 14w from solar and charging, maybe more panels? What’s the issue?Hi
The Hab Battery was charged the other day. Fogstar 105ah.
Charges on EHU Via Victron MultiPlus
Charges from Engine
But getting nothing from Solar?
Please see screenshotsView attachment 861381View attachment 861381View attachment 861383View attachment 861384
Yes because the victron shunt has a very small resolution and can pick up even 0.6w but it will round it up to 1w. The bms does not have a shunt, it uses a different method ( Hall effect sensor) that has alarger resolution, hence smaller currents will pass undetected.I've found that if the current levels are below a few watts, my Victron gear can still see the flow, but the FogStar BMS rounds it to zero.
Have you tried the JK app? The one with the blue/ white cloud.On another note I actually prefer the JBD app over Fogstar's own app.
If we're debugging an issue I find it more responsive for one thing. And easier to check settings.
That's good. It means the shunt I bought only a few months before I decided to go to lithium wasn't a total waste. And it explains why the Victron shunt appears to be more accurate when the van has been sitting for a long time with only parasitic loads on the battery.Yes because the victron shunt has a very small resolution and can pick up even 0.6w but it will round it up to 1w. The bms does not have a shunt, it uses a different method ( Hall effect sensor) that has alarger resolution, hence smaller currents will pass undetected.
The only bms that uses a shunt that I know of, is a Batrium or REC bms, and they are few hundred quid, 7-800 for the basic.
Yes, use it a lot for JK BMS (that's what we use in our batteries). I like the app on the whole, just wish they made the SOC the most prominent figure.Have you tried the JK app? The one with the blue/ white cloud.
Im not sure !I see 14w from solar and charging, maybe more panels? What’s the issue?
JBD ?On another note I actually prefer the JBD app over Fogstar's own app.
The shunt is great when you have very low current draw (like a parasitic draw).That's good. It means the shunt I bought only a few months before I decided to go to lithium wasn't a total waste. And it explains why the Victron shunt appears to be more accurate when the van has been sitting for a long time with only parasitic loads on the battery.
Fogstar build their batteries using a JBD BMS.JBD ?
Wow, much closer but still out a bit. At least you can configure some aspects of the shunt!I've not used the van for a few weeks. My FogStar 280Ah said it was full. The Victron shunt said I was down at 20%. I plugged it in and the charger put over 200Ah in, so the shunt was much closer.
Depending on firmware, the later firmware allows a cel voltage trigger the 100% SOC and measures current a little better. This improves SOC accuracy. I got a newish JK_B2A8S20P hardware V11.XW running V11.288 and it has this setting.Yes, use it a lot for JK BMS (that's what we use in our batteries). I like the app on the whole, just wish they made the SOC the most prominent figure.
