Help With Victron Solar Not Charging Fogstar Please? (2 Viewers)
Jul 18, 2009
11,352
18,400
HYMER B644
The Hab Battery was charged the other day. Fogstar 105ah.
Charges on EHU Via Victron MultiPlus
Charges from Engine
But getting nothing from Solar?
Please see screenshots
Steve N Tracy
1,246
3,775
Southampton
4 Years
The output from the victron unit needs to be higher then the battery voltage to put any noticible charge in your pictures show they are very close to the same voltage.
654
728
North Brum
Parasite drain in your van is possibly consuming the nominal charge going in from the solar. Is it sunny and where in the world are you? UK solar can be woeful this time of year.
Sep 29, 2007
814
1,196
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Because Victron MPPT can buck but not boost, the panel must have a higher voltage than the output. In fact, it must be at least 5v more for the MPPT to kick in, and in your case it’s lower. As a rule of thumb you need more than 19v from the panel for the MPPT to kick in To charge at 14.2v
May 31, 2015
11,895
45,490
Ducato PVC
Getting Better
Did the garage disconnect it for some reason..?
Disconnect the controller and connect the battery to the controller first then connect the solar….
Sep 17, 2017
5,703
10,702
Birmingham, UK
A-Class
I've found that if the current levels are below a few watts, my Victron gear can still see the flow, but the FogStar BMS rounds it to zero.
So could be it that the solar is pushing in an amp, but with other parasitic loads, not much reaches the battery and the FogStar is calling it nil?
Sep 29, 2007
814
1,196
Wantage, UK
What you say is valid, but in his screenshot the state is “Off”, so it’s not activated charging at all yet.
Dec 2, 2019
3,667
7,919
Amersham
van conversion
Since 2019
Are we looking at the same pictures? I see the solar charger producing few wats, all good, and bms charging enabled, wether that charge makes it to battery or local loads needs measuring. The bms can not see small currents, it does not have a shunt, it measures by a Hall effect sensor that’s inaccurate below 2 amps and no detection under 0.2A.
All looks good to me, besides of lack of solar panel output.
Sep 29, 2007
814
1,196
Wantage, UK
All correct but look at the State on the VC status screen ... it's Off.
Edit - my bad, I caught a glimpse of the "load output"
So yes, it is the BMS not registering anything.
...serves my right for posting while distracted by Six Nations!
Dec 2, 2019
3,667
7,919
Amersham
van conversion
Since 2019
Sep 29, 2007
814
1,196
Wantage, UK
On another note I actually prefer the JBD app over Fogstar's own app.
If we're debugging an issue I find it more responsive for one thing. And easier to check settings.
Dec 2, 2019
3,667
7,919
Amersham
van conversion
Since 2019
Yes because the victron shunt has a very small resolution and can pick up even 0.6w but it will round it up to 1w. The bms does not have a shunt, it uses a different method ( Hall effect sensor) that has alarger resolution, hence smaller currents will pass undetected.
The only bms that uses a shunt that I know of, is a Batrium or REC bms, and they are few hundred quid, 7-800 for the basic.
Dec 2, 2019
3,667
7,919
Amersham
van conversion
Since 2019
Have you tried the JK app? The one with the blue/ white cloud.
Sep 17, 2017
5,703
10,702
Birmingham, UK
A-Class
That's good. It means the shunt I bought only a few months before I decided to go to lithium wasn't a total waste. And it explains why the Victron shunt appears to be more accurate when the van has been sitting for a long time with only parasitic loads on the battery.
Sep 29, 2007
814
1,196
Wantage, UK
Yes, use it a lot for JK BMS (that's what we use in our batteries). I like the app on the whole, just wish they made the SOC the most prominent figure.
Sep 29, 2007
814
1,196
Wantage, UK
The shunt is great when you have very low current draw (like a parasitic draw).
For example, less than half an amp. The shunt is remarkably accurate whereas the BMS is usually out by about 50% at those levels. Over a few days/weeks the BMS SOC gets further from the truth - and it all resets if/when the battery is fully charged (and solar at this time of the year is hopeless). We have observed this with JK and I know Fogstar say the same thing of their JBD BMS's.
... one of the reasons I like the Victron Smartshunt!
Sep 17, 2017
5,703
10,702
Birmingham, UK
A-Class
I've not used the van for a few weeks. My FogStar 280Ah said it was full. The Victron shunt said I was down at 20%. I plugged it in and the charger put over 200Ah in, so the shunt was much closer.
Sep 29, 2007
814
1,196
Wantage, UK
Wow, much closer but still out a bit. At least you can configure some aspects of the shunt!
Dec 2, 2019
3,667
7,919
Amersham
van conversion
Since 2019
Depending on firmware, the later firmware allows a cel voltage trigger the 100% SOC and measures current a little better. This improves SOC accuracy. I got a newish JK_B2A8S20P hardware V11.XW running V11.288 and it has this setting.
The older firmware same bms, (got both) does not have the SOC-100% trigger voltage.
You have to check hardware, many older ones can be flashed with newer firmware.
May 30, 2019
726
1,048
Aberdeen, UK
Adria Twin Supreme
Since 2018
Fogstar told me when I questioned the accuracy of their BMS app that it’s purpose is to protect the battery and the app would not be accurate. They recommended I fit a SmartShunt, I’m amazed how different they are.
