Help please! Fridge not staying lit.
errpaul
Wiltshire
11 yrs
We are currently in France and our fridge, a Dometic 7505 is playing up.
It won't stay lit on gas.
It ignites immediately and stays lit for a few seconds whilst the ignition is still clicking.
Then it simply goes out. The red light on the front of the fridge flashes just before the flame dies. Maybe that means there is some kind of electrical cut off shutting off the gas supply.
I took the cover off to clean the burner.
Closer pic of the burner area
Yes, thermocouple it’s the copper looking tube that comes out from the flame, look to see that it isn’t touching any metal on is way into its housing, also give it a clean and make sure the end is properly in the flame... if that doesn’t work then a new one is the first cheapest option to try.
It seems to be clear of any metal. Is more or a grey colour at the tip where it sits in the flame.
Have you got a good flame?
Mine did similar last year thermal couple fine burner jet ferrked
Just small flame bought new burner(fleabay) ,now perfect
You need a new thermocouple, they burn out at the end - not obvious
That's the flame. Blue at the bottom. Slightly orange in the mid top bit
Flue is clear
So a new thermocouple...anyone know of anywhere we might get one between disneyland paris and Colmar which is our next stop.
Just check that the nut at the other end of the copper pipe goes into te gas valve is properly seated. The thermocouple doesnt generate much voltage, more a current generator and the slightest poor connection looses the power ( that holds the gas valve open)
A bit hard to know but most problems are from rust falling back down the flue and spoiling the flame. You should be able to hear it gently hissing away
Dometics website lists lots of dealers in France but quite likly a decent caravan dealer would have the spare thermo. Do you have the part number?
Best wishes
Mike
errpaul.
When searching for the part using RM7505, the number appears to be 2932333020 Dometic Thermocouple [Dometic Spare Parts], which applies to other model numbers as well.
From your photo, it doesn't look to be a very long thermocouple.
This one comes up using the same Dometic Part No.
Good luck,
Jock. :)
P.S. See your other thread for a list of Agents in France. :)
