Hi,
Installed the shower point through the sidewall no problem- a bit stuck on the connections due to odd pipe Size! Have a Chausson 627GA 2018.
Problem is the reinforced hose is neither 12mm or 15mm - seem to be approx 14mm OD & approx 10mm ID.
The installed joints seem to be marked JG & are barbed connections with retaining clips (see pics)
Been googling for a while & cannot find suitable fittings!
Need a T piece, in line valve & a way to connect onto the 15mm inlet pipe of the Bullfinch shower.
Any ideas?
Many thanks,
Rob
Any ideas?
Many thanks,
Rob
