When you find out give me a shout, ours is much the same. My first thought is the jet might be blocked slightly. That's my first job to check when I get back to use my compressor.We have a Dometic 7 series AES fridge freezer.
Over the last few days the fridge has stopped working on gas but the freezer compartment is working ok which seems strange.
We have checked the burning chamber which is fine.
Any ideas?
Where are you? Is it hot where you are? Do you have it turned up too much? These are some factors and I'm sure others will be along to give more...
Thanks for all your input.
@Dazzlin We are both well thanks. Enjoying the new van (apart from the probs with the fridge).
Where are you two at the mo??
Not really wishing to contradict the OP but our 7 series fridge has only one burner.Bloody hell
ours is doing exactly the same thing
didnt realise they had two jets
I assumed it was the thermostat.
Will have a go at the jets when the crappy rainy weather in Wales stops peeing down
We need to heat up any drinks
If it's low on coolant it must have leaked as they are a sealed system as far as I know so a pretty good guess would be a NO to a refill.
