movan
Help. None of this makes sense.
Before I go on and on can you tell me something. If the engine is running.. (I have an engine, 2 leisure batteries quite new, 2 solar panels, a battery master)......... and a garage man puts a multimeter or whatever it's called on the engine b, and checks and says if battery receiving powerand says, therefore, 'No. You don't need a new engine battery, it' s good and receiving power. And I say, 'Yes. But it' s receiving power from leisure battery I think cos panel indicator flashing that leisure batteries are GIVING OUT 6.3 V.! '
He says,' Oh, I know nothing about leisure batteries. '
What is your advice/info re engine battery problem, not the man.
The engine battery intermitently is dead as a dodo. No chugging. Then after several attempts its starts.
Sometimes it seems connected to gas flint!!! Or sat nav plugged in!! But not always.
After driving 8 hours, the readings on both sets of batteries are about 13.1 then the engine battery drops quickly and the leisure tops it up.
Overnight, they both drop to 12.5/4 but now (cloudy day) they're up again to 13.1.
Don't forget no tve, etc., just phone charger and occasionally Dongle.
Please don't tell me what to do like disconnect the the red wivwot and split the green dingdong and push wire into the wotsapop... I won't have a clue. Sorry.
Can you just tell me BASICALLY what you think is causing the problem. Really appreciate it if you're still with me up to the end of post. X
