PussyGalore
- Oct 31, 2020
- 5
- 0
- 1994 Renault Trafic
- Van virgin
Hiya, you lot seem like a friendly (and more importantly, knowledgeable) bunch, so having picked up my new (1990s) Elddis yesterday, I have a few questions and was wondering if anybody could offer advice. I registered last night while watching a Sean Connery obit on the news so the only username I could think of is Pussy Galore (I regret nothing).
I bought the MH to be able to live off grid for 2 weeks at a time, with no hook up at all (though water and waste disposal won't be a problem), so I was hoping solar would be my answer. I could fit a few 100w panels on the roof, certainly. I only really need electricity for the water pump, and to charge my laptop and phone in order to WFH. It's only a small laptop (Lenovo Chromebook) so I'm anticipating this being possible hopefully?
I'm hoping, and having done some research, that 2 x 4.5kg gas canisters will be enough for heating, cooking, refrigerating and washing for two weeks.
As well as the two general queries above, I have more;
1. I drove the MH for 3 hours yesterday, and have had it on EHU for a few hours today, but the leisure battery indicator is still showing the red 'low' light. Is this normal? If it was almost depleted when I bought it, how long would it take to charge it? There is enough in there to turn the lights on but they're very dim. The seller had no idea how old the leisure battery is so it probably needs changing.
2. With the MH on EHU, the plugs are working, but I don't know how to turn the lights or the water pump on, on EHU. The switch has to be set to either the starter or the leisure battery for these to work.
3. The leisure battery is under the bonnet. If I needed/wanted a second one to double my capacity, would it have to go under there or could it go inside the MH somewhere and still be wired in parallel? I don't think there's space under the bonnet.
4. I can wire a plug, and change a bathroom tap. Could I install solar panels? If not, anyone know someone/somewhere in Norfolk that does?
5. The MH has two 250v plugs, but they're useless without EHU or without an inverter right? I think I can do without any 230v appliances because my Chromebook has a USB-C power input and I think a 12v charger would charge it (albeit slowly), but having said that I would need 12v charging ports wouldn't I? There is a cigarette lighter in the cab but presumably that only draws power from the starter battery. I'd need to install 12v chargers in that case, right?
Basically I need someone to tell me exactly what I need to do to sort out my electrics.
Thanks a bunch.
Patrick
Thanks a bunch.
Patrick
