Heating in rear of Lyseo with Fixed Beds (1 Viewer)
Sep 28, 2021
50
68
West Lothian, UK
Burstner LyseoTD690G
Since 2019
Hi folks, just back from our first really cold weather trip in the Lyseo TD 690G. We had a couple of days over New Year at minus 4 and noticed that the blown heating that runs along the side of the fixed rear beds was not working and noticeably cold given the weather. The heating system is Truma.
All the vents were working in living area, bathroom and garage but there was no heat making it's way upwards from the pipe behind the wardrobe / storage drawers on either bed into the blow pipes running along the wall, basically the area circled on the diagram
Just wondered if anyone else has experienced the same issue? Am I doing something wrong? Do I need to turn this on somehow? I read in the manual about a 3 way valve for rear beds, does anyone know if this is something that also exists on the Truma system? Or only on the Alde? I looked around but don't see it without unscrewing the panels from the garage.
I tried closing vents further forward to see if that would push air back but it didn't and the bathroom one cannot be closed as it's an actual vent versus butterfly closure. Also generally run on Eco mode but also tried High and Boost but again nothing.
I have sent an email to Burstner Germany but they're out until next week.
If anyone has any similar experience or thoughts would appreciate them
8,496
11,538
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I blocked the garage heating of as waste of heat. I pushed 2" pipe lagging into the gaps in the garage by the beds and laid 25mm Celotex under the bed rails.
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
Thanks Stealaway, I was hoping you'd see this knowing you also have the 690G.
However, doing all this does this mean you had the same issue of no heat coming through those tubs by the side of the bed/wall? Or was it working but just not enough heat then you also done this?
I may be looking at your solutions if I cannot get this heat by the bed working as we generally use our motorhome all year round.
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
Quick update on this one. At home over the weekend via the house mains supply I tried this again, touched nothing but suddenly I had hot air coming out around the bed. It wasn't overly strong but it was there and where the cuts are mostly pointing downwards.
Followed Stealaway's advice with a trip to Screwfix and packed the gaps with pipe lagging and also gave the tubes a good twist to try and point the cuts up diagonally towards the wooden plates on the walls and left on for 30 mins on Eco / Mix 2 and could see a noticeable difference in rear temperature.
Unsure why I had nothing on site then a little at home 🤷‍♀️ but hoping the pipe lagging will help.
Motorhomes - the gift that keeps on giving :ROFLMAO:
Jan 17, 2018
155
466
Sunny Poole
Low profile Burstner
3 years and learning
Hi Alex
We used your pipe lagging trick but are now suffering from quite serious condensation in the garage. We are considering blocking the heater outlet . Have you had any condensation before or after blocking the heater outlet?
Jan 8, 2013
8,496
11,538
Burstner Lyseo 690G
Oh dear.
I've never had condensation in the garage but we don't use the van in winter.
I had thought about blanking off the heating plpes around the bed but they are all above the pipe lagging.
Have you fitted the lagging from inside the garage upward?
There is no other heating into my garage.
53,858
151,717
Have you checked the black knobs at the start of the bed vents, they arevery lose so easily knocked, you can rotate them to turn the air supply off and on.
German Vans always seem to set up the van so the bedroom area is quite cool.
32,704
66,744
Lenny ... With all the research you've done on Carthagos should I have black knobs somewhere? 😃
Jun 30, 2011
7,268
20,278
Barnard Castle, UK
Concorde Concerto
Was the heating on the site on electric?
At home when it’s working your home EHU more amps so more oomph into the system?
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
Hi Paul, it was on Mix 2 so yes using the electric on site. This was my assumption of just more power from my home electric also on Mix 2.
Interesting reading some of the comments above. Alanben - have you also experienced either nothing or little heat in the bedroom area? Stealaway I fitted the lagging from the garage upwards and also twisted the heating pipes a little upwards so the cuts in the tubing were point up and angled towards the wall.
Will be interesting this weekend as planned to be away, it's minus 4 just now so similar to what we had over new year, see if we have the same experiences and also with the lagging see if we get any condensation in the garage area.
One difference though we've invested in a new Silverscreen which just came last weekend so that will get a run out this weekend and help with some internal heat although the living area wasn't really the issue, it was the bed area.
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
I also got a response from Burstner where I emailed pretty much the same question and images as above. The response below :confused:
Thank you very much for your message!
Unfortunately, we have to inform you that we do not offer this heating system, which is why we can neither clarify nor recommend one.
We ask you to contact one of our Bürstner dealers directly. they can best help you on the vehicle itself and check the performance of the heating again
You can find a list of our partners on our homepage
www.buerstner.com/uk/contact/find-a-dealer/
Thank you for your understanding.
Please reply to this e-mail with any comments or concerns.
Best regards
Your Bürstner-Team
Feb 14, 2021
3,688
7,972
Milton Keynes, UK
Burstner Lyseo 727G
I would have thought the fan would perform the same whether on battery/low ampage electric or full fat. There fore the air flow should still come through - just maybe not as hot. I guess the heat will be the poorest at the beds as it's at the end of the the system. You could try shutting off the outlets elsewhere and see if it improves the output at the beds.
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
Someone more knowledgeable than me VXMan can say whether the fans should perform the same. I initially thought something was broken or needed turning on because I couldn't get heat to the rear. Per my OP I did close all the vents further forward except the bathroom which can't be closed to try getting more heat in the rear but it didn't do anything noticeable (although the cuts in the tubing running alongside the bed were pointing at a downward angle), hence thinking something was broken, or needing turned on. That 3 way valve in my OP since I cannot find it anywhere and took the access panel in the garage off to check there I assume is only on Alde heating and not Truma.
Blocking the cold air from the garage with the lagging for this weekend should help for sure, but if again there's no heat coming to the back it will be another cold one. We ditched the Duvalet's moving from Autosleeper singles to Burstner fixed bed, they will be going along this weekend just in case :ROFLMAO:
DT
Dec 27, 2020
441
1,386
Shropshire
Burstner 690G
Boats Caravans & Motorhomes for 25 years
As it happens I have brought my 690G out of storage today, gave it a good hours run and now have it on EHU at home. The van is empty of almost everything including the bed mattresses. Despite emptying down the water prior to going into storage early December found some ice in the water tank and will be sponging that dry later today. With Truma going the two heating pipes that sun alongside the bed frame read only 8'c. Later will shut all forward vents and see if that makes a difference and I will probably block up the garage vent which is useless. I dis the foam pipe insulation a couple of years ago and that definitely makes a difference. I have considered putting some sort of mains heater in the garage but the jury is still out.
53,858
151,717
I didn't know about your preferences for black knobs in bed. :rofl:
I'm not sure what Carthago do but I assume they fit the metal heating vents along the side of the bed and the knob is where the heating pipe joins it.
Just been out and taken a pic of it in my van.
Feb 14, 2021
3,688
7,972
Milton Keynes, UK
Burstner Lyseo 727G
I have a 727G with rear single beds. So pretty much like yours but longer.
I just did a little experiment on my drive. The fan speed is constant no matter whether it is powered by leisure battery or EHU (thought: Does it actually power directly from the EHU or is it always powered by battery whether plugged in or not?)
The heat obviously varies according to Gas/El1/EL2/mix selection.
The blower output to the beds does vary depending on how many vents are open along the way. I found the Passenger side bed stronger than the driver side bed. Our pipes do not have any cuts in them. They come up near the foot end of the bed and point towards the rear. I always find the toilet the warmest room in the van.
So, I cannot see your problem has any relation to electricity supply. That would either power the selection or trip the power supply if it was not enough (had this happen on some low power sites in the past.)
It must be some problem in the pipe work. Although odd if you say it works at home but not in storage.
One other comment -seems to be more heat coming out of the outside vent than in side!
Jan 17, 2018
155
466
Sunny Poole
I definitely don't have a black nob! maybe because I have a Burstner not a Carthago :giggle: I'm going to insulate under the beds as per Stealaway's suggestion.
53,858
151,717
The black Knob is in my Hymer.
Edit:
Perhaps I should have rephrased that better. :LOL:
AndyPK
5,032
14,123
Cirencester
None……..!
Motorhoming since 2015......
Perhaps the answer to your problem j8snl , is an electric underblanket (but only when on EHU…..)?
Feb 14, 2021
3,688
7,972
Milton Keynes, UK
Burstner Lyseo 727G
The heater fan is 12v.
Ah, OK. So blowing performance will be consistent what no matter whether you are plugged in or not. That puts paid to the theory about amps affecting the performance of air coming out in the bedroom - unless the battery was going flat when off EHU?
Jan 8, 2013
8,496
11,538
Burstner Lyseo 690G
Alex
Did you fit the pipe insulation up from inside the garage and below the heater pipes around the bed?
53,858
151,717
The fan speed is controlled by the controller.
ManTheVan
1,480
2,821
South Devon, UK
Rapido C class
Yottie convert
Ours isn’t a Lyseo or any other kind of Burstner, but has a Truma combi system. What we’ve found is that when operating the heating on EHU alone, the fan remains low and heat output is relatively poor. By switching to Gas only or gas/electric combined, the fan really picks up and heating is very rapid and powerful.
Were you on EHU only? If so, it might be worth trying switching to gas and seeing if it makes a difference.
j8snl
Sep 28, 2021
50
68
West Lothian, UK
Since 2019
Hi ManTheVan, if this was based on the original posting yes I was on Mix 2 with Gas and Electric.
I think we are establishing though through this thread that Burstner’s of this rear bedroom layout above the garage are just cold :LOL:
Jan 17, 2018
155
466
Sunny Poole
ManTheVan
1,480
2,821
South Devon, UK
Rapido C class
Yottie convert
Sorry to hear! Ours has a rear bed that’s also above the garage, but the garage is heated too, so we’re always cozy.
Definitely a thick duvet and brushed cotton sheets/duvet cover in winter. The brushed cotton makes an incredible difference. Equally, if you go for an electric underblanket (on EHU) you won’t know yourselves!
Good luck!
