Have I wrecked it ?
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I tried using my multi meter on 230 volts and had it set wrong ... Pop went a fuse internally.
I've replaced the fuse and the display seems to work but all readings are nonsense
Have I wrecked it, I think I know the answer....
Its dead Jim.. Wouldn't trust after that
Been there got the medal
I really will have to try reading the instructions in future.
Crash course in multi meter usage I think
Thanks to all for the confirmation
Don’t replace the fuse with a metal screwdriver bit, then check the voltage on a battery but forget you had it plugged into the amps socket......
I thank my lucky stars it was an external battery compartment.
if as i expect this is just a cheap £10 meter, save the leads and battery and put the rest in the bin. All they are is a plastic case, a few cheap chips on a mass produced board with a cheap LCD screen. Certainly not worth trying to recalibrate.
Learn from your mistake and its a cheap lesson
I wish I understood all the above posts. :(.
IIs it something I should worry about?
It was indeed a cheepie from Aldi,
A replacement is on my Christmas list for Santa
