Gushing grey water (1 Viewer)
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
Hello all, not the usual grey water thread, but we do indeed have a gush, or we did until the tank ran out
Luckily we were home with a hose connected to drain
I can not now close the valve, it is connected via what looks like bike hand brake cable kind of linkage about 2m long
The handle I normally pull to open the valve will now push in but springs out, even when the handle is pushed in the valve is still open
Those that know me already know I don't 'do' when it comes to fixing things, but I might actually have a go at this, presuming somebody tells me what I need to buy and how to fit it :whistle:
Actually already thinking it will have to go to a workshop, unless anybody thinks I might be something simple that I can fix :D
19,346
30,235
Hi David
I don't know your system but it sounds like there should be a spring that isn't there anymore, go on get in there and get dirty you might even fix something.
When it worked "proper like" did you have to hold the handle out or did it lock I some way.
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
Thanks Martin
The handle pulled out to open the valve and stayed there by friction, pushing the handle back in closed the valve (or used to at least
Logic would say it has become disconnected at the valve end, or broken in that same general area
David
MrsBB
112
57
Derbyshire
Hymer a class
10 years after many years tugging
Oh no...... Least I'll know what's happened in future! Hope you manage to sort it.
19,346
30,235
When you push the handle in and it springs back out suggests it's still connected to something just that something is now too tight to move, as in too tight or has not got the help of a spring was my thinking, I could be completely wrong.
Sure somebody will be along who knows more than me.
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
Have you tried the first thing when most things stop working..............A good spray all round it with WD40.
Try spraying all around the valve and pushing the bit the cable attaches to
wasp
1,724
18,180
Warsop
None gone caravannin
Have been underneath to ave a look you
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I have given it a good looking at, but not been underneath, I can see where the cable runs to at the outlet from the grey tank where the valve must be situated
I will get under tomorrow and have a closer look and maybe a prod, but I am more likely to make it worse than fix it, unless I get very lucky
Apr 9, 2013
663
373
Ayr
If it's operated by a Bowden cable it sounds like the cable outer has become detached at one end or the other or the outer is stretched/unravelling. I could be just that the valve is sticky and the cable isn't "man enough" to push it back closed. Bowdens work best in tension application although a rigid cored one can push as well as pull.
17,630
43,277
they tend to be similar in operation to a bike brake dont they? with a return spring to close the valve as the lever is pushed across. it may just be the spring has popped off, or the shutter on the valve is jammed
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
If it is a blade valve, like an RV, these often stick and might need replacing every ten years or so. The US parts are pretty easy to replace, but no idea how European equivalents would be. Normally, a sudden sticking is due to foreign matter (i.e. toilet paper or other foreign body) blocking the blade from fully closing. In this case, you may be able to dislodge the blockage by using a high pressure hose up the outlet.
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
Thanks for that, I think it will be a blade valve, but probably only a small one compared to RV's, I think the pipe size is 1.5 or 2", it is only grey water, we have a separate black tank
But thinking about it we had added a potion to clear the grey tank before leaving site today, that suddenly makes sense, maybe a lump fat has come loose and got stuck at the valve, I will refill water tomorrow and run hot water through
I will also see if I can see what is fixed to what tomorrow and hope to push the valve closed from outside, the pipe has a 90 degree bend near the end that will make jetting quite hard
David(y)
Chris
21,053
278,728
10 years
Just leave it open like I do.
The amount of time you save not having to faff around emptying it you wouldn't believe.
It leaves more time to look for somewhere discreet to dump the cassette.
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I have taken a few photos but can only upload this one, all the other say file too big, I have now identified that the cable outer is detached as suggested by Tim (thanks), I have also discovered the whole thing looks to be a massive overkill
The cable goes about 1m in total, including quite a sharp bend, it looks like a real job to change and part probably only available via Hymer
So what do you think to me cutting the pipe in the top photo between the bracket and the 45 degree bend, then fitting a decent ball valve, it is quite easy to get at to fit and then use, seems a much better way to fix the problem, if it ever got blocked I would have a half chance of poking something in from the outside
Not too sure about the pipe size, looks to read 1"1/4 and 40? mm, I know from work that metric / imperial are measured internally and externally, so is it 40mm OD and 11/4" ID?
Anybody got any better ideas about this?
11,932
9,082
Hi David look at ball valves
that should do the trick -put one in line and leave the cable one open
terry
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I have found that the outer is detached at the handle end, so form your knowledge is that mendable or will it need a change of cable
See above post, to me it looks a big job to change the cable and it will still be a bad way to do the job IMHO, unless the cables can be mended it would then probably be a quicker fix
David
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
terry
Thanks Terry
It is nice to have your approval, seemed like a good idea when I looked underneath, no idea why Hymer did what they did
Ordered valve, hope it is 11/4", I'll be up to see you with MH and valve in hand :D(y)
David
11,932
9,082
I''ll remember to pack a hacksaw ;)
terry
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I have only gone and fixed it myself :rolleyes:
It doesn't stick out beyond body, looks on this photo like it does, but wheels are recessed on my Hymer
No idea quite why Hymer made is complicated in the first place
and note valve set in correct position for travel :whistle:
Thanks for input and advice (y)
11,932
9,082
very good David (y)Satisfying doing a good job yourself ;)Hope Bev kept you supplied with coffee (y)
terry
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
terry
It was and is, thanks
Bev did coffee, then beer, not sure if I am proud or sad, but Bev sorted out my final problem, not having enough pipe to refit a bend
Why do we need a bend? she says, 'because it had one before' say I
Why do we need a bend? she repeats, I pause
Can we not do without? she asks, I stay paused already realising she is of course completely right
Could we not just fit the bend if we need it? she adds, I am still stuck on pause, but now realise not only is she right, she also has the next issue covered
Decided I am proud and more than a bit lucky to have her (y)
David (and Bev) ;)
11,932
9,082
Nothing like a woman to keep you grounded and keeping an eye on your wanting stuff but not needing it ;)
terry
