Green horn (1 Viewer)
May 14, 2014
617
744
Now a little one
Look under the passenger seat. Instructions are in the owners manual showing how to lift seat for access.
Tombola
4,837
15,732
Merseyside
Rapido 8094DF
possible where the passengers feet go
Tombola
4,837
15,732
Merseyside
Rapido 8094DF
A
andy$
5
Chasson 781eb
Ford
Feb 22, 2011
9,800
20,201
Newcastle under Lyme
Hymer B544 A Class
w2f
The more information you can give, model, base vehicle and age etc the better replies you will get.
Thats what I find anyway 👍🏻
A
andy$
5
Chasson 781eb
Ok thanks it a Ford. Chasson 718 eb 16 platexroll:
May 29, 2013
2,603
19,277
Tyneside
Chausson best of Flash 10
Several years now
Probably under the passenger seat then.
If it's like our Chausson you have to unbolt the seat and remove it before you can fully access the battery.
What is the problem with the battery anyway?
A
andy$
5
Chasson 781eb
Hi thanks I thought the 1 under the passenger seat was van battery? .the reason I am asking is. I want to fit solar panels
Swifter
3,914
9,041
Herefordshire, UK
Since 2019
Have you looked under the bonnet to see if there is a battery ? 👍🏻. Leisure battery inside and engine battery in engine compartment?
Tombola
4,837
15,732
Merseyside
Rapido 8094DF
the llink to the manual above should tell you what you need post number 7
A
andy$
5
Chasson 781eb
Thanks everyone I will check that out:xThumb:
May 29, 2013
2,603
19,277
Tyneside
Several years now
As I said, to fully access either of the batteries the appropriate seat has to be removed. If you have a swivel seat then it's easier to remove the seat bit first, then the swivel part, as added together they are damn heavy ! You need a torx wrench. T40 from memory.
