Green horn
Look under the passenger seat. Instructions are in the owners manual showing how to lift seat for access.
possible where the passengers feet go
w2f
The more information you can give, model, base vehicle and age etc the better replies you will get.
Thats what I find anyway 👍🏻
Ok thanks it a Ford. Chasson 718 eb 16 platexroll:
Probably under the passenger seat then.
If it's like our Chausson you have to unbolt the seat and remove it before you can fully access the battery.
What is the problem with the battery anyway?
Hi thanks I thought the 1 under the passenger seat was van battery? .the reason I am asking is. I want to fit solar panels
Have you looked under the bonnet to see if there is a battery ? 👍🏻. Leisure battery inside and engine battery in engine compartment?
the llink to the manual above should tell you what you need post number 7
Greetings peeps welcome from Bexley
Thanks everyone I will check that out:xThumb:
As I said, to fully access either of the batteries the appropriate seat has to be removed. If you have a swivel seat then it's easier to remove the seat bit first, then the swivel part, as added together they are damn heavy ! You need a torx wrench. T40 from memory.
