Globecar Newbie | MotorhomeFun | The Motorhome Support and Social Network
Globecar Newbie
Aug 17, 2019
12
27
NE Scotland
Carmen the Campscout
Just starting out....
Hi Folks,
Try to heat the van up enough to stop the water autodumping but cant figure out the setting on the Truma CP Plus control panel for heating without the boiler.
Can anyone help?
Aug 10, 2013
1,990
2,194
Vienne, France
Globecar Summit 640
Since 2014
Select the motorhome icon with the rotary control, then push it. Select the desired temp with the rotary control, then push it to confirm.
Big Stevie
Aug 17, 2019
12
27
NE Scotland
Do that and leave the boiler switched off until correct temp achieved and water tank filled?
Oct 29, 2008
3,858
2,934
West Yorkshire
PVC
since 2008
Rotate button till the gas bottle and lightning sign are flashing, push button to select rotate button for gas or electric or both, press button to select.
Then rotate button till motorhome symbol flashes and press button, rotate button to selected temperature and press to select, then leave to heat.
Bare in mind even on blown air heating the water will still get heated and if on a long time the water will still get very hot. This is not a fault.
Big Stevie
Aug 17, 2019
12
27
NE Scotland
One last question folks..
Do I need to reset the dump valve or does it automatically close at the required temperature?
TIA
Aug 10, 2013
1,990
2,194
Vienne, France
Globecar Summit 640
Since 2014
You have to reset it. I think on older ones you pull it out, and on newer ones you push the button.
Big Stevie
Aug 17, 2019
12
27
NE Scotland
Cheers, Another trip to the storage yard required...
Friendly professional service from qualified technicians
West Country Motorhomes
Rhino Installs
