- Jul 5, 2013
- 11,727
- 13,706
- A class
- Since 2013
Well I can't change my mind now and the money has been spent .
My 2 x 120Ah low profile LiFePo4 batteries from KS Energy have arrived . Both were at about 80% charged so I am charging them to full now as per the instructions. Downloading the app and connecting via BT was easy. The Votronic BTB should be arriving this afternoon from RoadPro and all the other bits to do the job should be here by the end of the week at the latest, I hope. The only one I am keeping my fingers crossed for is the Votronic 350W MPPT solar charger which is coming from Germany (couldn't find any in the UK). It has been purchased through the UK Amazon site so if they don't deliver I can easily get my money back. In that case I will wire up my existing controller until I can find the one I want.
I have spent some time thinking about how to install it all but I need some advice. I am going through the EBL to connect both to make it easier. I do not want to disconnect the cab battery unless I have to. So first question is can I just remove the 50A fuse on the cab battery or are there more connections? I will also remove the 50A fuse at the habitation battery as well as the fuses for charging by mains and solar on the EBL. So the second question is does that mean I can keep the EHU plugged in while I am doing the job?
At the moment I am hoping to do it in the following order.
Just to explain that I am OK with the basic principles of electrickery but I cannot understand those spider's webs that electricians call wiring diagrams.
I am sure that I will come across some more questions as I get on with it, so I will add them to this thread. Many thanks in advance to anybody is willing to offer me any advice.
- Remove existing batteries I need them out of the way to make it easier to fit and wire up the BSB and solar controller.
- Fit the B2B and wire it up to the EBL and shunt terminal.
- Fit the solar controller and connect it to EBL but I will not wire in the panels at this stage.
- Fit the new batteries and change the settings on my Victron BMV 700.
- Wire the panels into the solar controller
- Replace all the fuses I removed and check everything is working.
