Gaslow Issues! (1 Viewer)
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
Below is the gas low system on my Adria ,, I have been getting it ready for new season but no gas is flowing the tanks are full ???? Cooker and fridge and heater not getting any gas flow after 15 minutes of trying .
The valve with green red triangles in centre is it automatic change over ?? or does it matter which way it is turned ,, Gas low manual with this van is not for this model ???
Also I cannot find any gauge that is compatible with this setup and I have been to 3 motorhome retailers about it they all say it is obselete ,but I have receipts shoing its only 2 years old ???, so im now asking here for advice
Al n Val
2,311
5,725
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
The gauge is showing that it’s only partially opened the valve hence no gas flow, the valve should be showing full green to be open
It’s probably stuck so unless a gentle tap doesn’t release it i’d get it changed
jerryz
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
Its been like that since I bought the van last year ,???? everything was working when I put it in storage ,,,only switched the cylinders off ... drained the heater and water and waste tanks etc ,,,, when I turn it to right more green shows and to left more red shows , but I was told to leave it in the middle ????
Nanniemate
6,241
43,764
Wales
IH
Oh dear I had similar last week all fine when put to bed was away so hadn't used and busy too it out no gas ended up needing regular as it failed I was lucky mine was under warrantee
Give it a little tap that may help
jerryz
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
Is it not an automatic regulator the Green/Red Valve that changes from one gas bottle to the other ???
also where would a gas meter fit in this system for how much gas in each bottle ???
Basildog
2,216
3,622
Are you sure you have gas in the cylinders ?
First of all your cylinders are almost certainly out of date and really should be replaced, second those automatic changeover valves are notorious for failing, regulator looks old too .
Whoever fitted that system was obviously one of Captain silicone’s merry band of PTFE bandits ⚠️
Also someone has engaged in washing up in the gas locker ( sorry they have used washing up liquid as leak detection spray )
There are several different tests you can try but not knowing your skill set I will refrain from giving any practical advice.
Jan 22, 2013
146
196
Dorchester
since 2010
Auto change over valve. at the 12 oclock position there is a small white square, this should be at either 9 oclock OR at 3 oclock NOT as it is. This denotes the tank to be used first.
eg with the dome rotated to the 9 0clock position it points to the left tank. Rotate the clear plastic to the left, turn on the left tank and the indicator should show all green.
If it shows all red then, without doing any thing else turn on the right tank. The indicator should now turn green. If it is still red it implies if all is working, that both tanks are empty.
PeterCarole29
1,148
1,209
Colchester
Renault Master Fleetwood
20 years
You can pull out one of the bottles and it will be date stamped i think its on the lower ring
jerryz
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
The bottles are dated 23 /9/21 and 14/11/21 as i said i have receipts for them in the owners file .. The rest of it may be older ,,,
I have set the regulator to left hand bottle the Indicators are all Green so i presume the bottles are still full ?????and tapped the valve with hammer ,, but gas is Not flowing at cooker , oven , fridge etc the bottles both feel heavy so must have gas in .....
looks like i will have to replace the regulator valve and hoses ?????? But im not sure ,, which parts , Im a mechanical and electrics person not gas
Basildog
2,216
3,622
I have set the regulator to left hand bottle the Indicators are all Green so i presume the bottle is still full ?????and tapped the valve with hammer ,, but gas is Not flowing at cooker , oven , fridge etc the bottles both feel heavy so must have gas in .....
Both bottles are well out of date.
Technically they were out of date around 8 ago
The Motorhome retailers obviously don’t know anything about the gauge as they are readily available but I wouldn’t waste your money on them as they are about as much use as a chocolate fire guard 😮
I would be interested to see a receipt for your system that is 2 years old ?
Feb 14, 2021
3,692
7,985
Milton Keynes, UK
Burstner Lyseo 727G
Why do you say the bottles are 8 (years?) Out of date when the OP stated the dates in 2021 that are on the bottles?
May 7, 2016
7,337
11,865
West Sussex
Malibu Van 640 LE K
Since 2003
He first said he had a receipt showing they were purchased 2 years ago. That could mean someone was selling out of date stock. I think it is the two separate tank outlets that gives their age away and the dates could well be the expiry dates not the manufacture date.
PeterCarole29
1,148
1,209
Colchester
20 years
The date stamps are when they become out of date. I suspect someones pulled the wool over your eyes
PeterCarole29
1,148
1,209
Colchester
20 years
Or the owner bought new in 2021 and swopped them back when it was sold
Basildog
2,216
3,622
There’s out of date stock and then there’s vintage 😂
2012 was when the multivalve cylinder replaced these I believe.
We are seeing plenty of retailers still selling the older Truma regulators as new when the latest manufacturing date is 2018 😂
Industry practice is that a regulator up to 3 years can be classed as new , it’s why we list any older regulators as old stock.
I actually destroy them at 10 years old rather than risk selling them .
Don’t get me started but there’s too many clowns selling products they don’t understand and are only interested in profit .
May 17, 2016
3,632
7,874
Aberdeenshire
B524
2nd base
How sure are you these bottles are full? Apologies if I've missed it. You also need to double check the dates stamped on the bottles.
The whole system looks a bit messy especially the changeover valve. If the bottles are definitely full I'd say it's the changeover valve that's faulty.
Apr 30, 2018
2,007
4,470
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
First off I’m no expert, but your bottles look like they’re more than a couple of years old. I believe they should have small gauges (see photos attached). Also if you follow Jonasw19 #7 this will confirm you have or don’t have gas in the bottles.
Nov 1, 2023
110
2,866
Adria
DerryW is right about the small cylindrical gauges which should be on each bottle to let you know the level - although they're not great. I swapped the one on first bottle used for a Wave system which lets you see how much gas is left in that bottle. When that runs down you still have a full bottle during which to top up.
Gaslow are really helpful. Give them a call.
Nov 1, 2023
110
2,866
Adria
Sorry should have said Wave let's you see how much is left on your mobile
jerryz
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
OK had another go this morning , a few more taps on the gas bottle valves ,, brought the gas flowing
The fridge ,cooker, oven etc now work, and the gas bottles are both nearly full they weigh a lot and they dont weight much when empty,, also had to give the valve for the dometic fridge a nudge too now all is working , although I have not refilled the Truma heater with water yet .
Oct 12, 2009
10,778
23,874
A Class N+B Arto 69GL
Truma blown-air heating will work without water in the tank.
Apr 30, 2018
2,007
4,470
Mid Suffolk
Adria Matrix 670DC
Full bottle weighs 24.5kgs
32,706
66,760
They are very old cylinders and certainly need replacing as they are well past their safe usability date.
I got a recertified cylinder last year direct from Gaslow - at the time they had an arrangement where they exchanged our existing out of date cylinder for a previously out of date one which they had got in that in the meantime they'd had professionally refurbished and tested and thus was 'as new' with a new 10 year expiry date. This refurbished cylinder looks like exactly the same model as you have so yours are over 17 years old (the original cylinders had a 15 year certification, now it's only 10).
If you were told they were fairly new then you were mislead so may have some comeback on the seller.
To as to your woes the stainless steel pipes only have a 20 year lifespan so they'll need changing too, if not now, then certainly in the next few years.
jerryz
Jul 13, 2023
426
1,575
All over Europe now
Adria 680ST Gold
I will look into it ,, the van is nearly 15 years old but in excellent order
I will speak with dealer , but the bottles were put in by one of the 2 previous owners and I will ask them I have the receipts where someone bought them from in Kent.
Also would a Hab Check not have looked at the gas bottles ?????
