Gas Regulator (1 Viewer)
Jul 26, 2017
436
925
Elddis Accordo 125
Since 2016
The gas regulator failed in our van the other day. It took a while for me to figure out what was causing the various odd symptoms (all due to low gas pressure). I have now replaced it and all is well.
Do you carry a spare regulator or do they fail so infrequently that this is unnecessary?
R
Feb 22, 2016
3,632
10,881
York
Bailey 620 Approach
Needed to have our bulkhead regulator replaced before our winter trip to Portugal. Symptoms were low gas pressure if more than one appliance on. So, with water heating on gas, cooker wouldn't work properly i.e. too low pressure for rings.
Dealer replaced regulator and all's now well.
Dealer did say that this was very rare. Speculated that regulator could have been damaged by not turning gas off when refilling Alugas bottle.
musson
487
165
grantham
low profile
since Jan 2014
Mine failed and I fitted a gaslow with new stainless pipe and 5 year warranty direct replacement but you have to turn gas of when traveling.
Feb 22, 2016
3,632
10,881
York
Bailey 620 Approach
@icantremember- well the dealer who told me was not the highwaymen who sold me the used van and they do have over 20 years experience of this make of van (and others). So, until I see evidence otherwise, I'll take the advice of the dealer. He had no reason to make it up or to say anything if unsure.
icantremember
8,343
17,567
Near to Watton in Norfolk
Hymer T-SL668
since 2005
OK, good luck, I'm only speaking from experience.... and you did ask.
Feb 22, 2016
3,632
10,881
York
Bailey 620 Approach
Appreciate your advice and am grateful for your posting...but I didn't ask. Just for the record.:)
p-c
134
55
Berkshire
40 years
This has been covered on "other" forum. The general consensus then was carry a spare, which I do. Sometimes the failure is due to residue from the pipes blocking it. Bet yours will fail again just when you can't get a replacement all for the sake of a few £ and a little space.
The dealer mentioned above does not know what he is talking about. Filling a gas bottle does not go near the regulator unless you are using gas at the same time!
Regards
P
Feb 22, 2016
3,632
10,881
York
Bailey 620 Approach
"The dealer mentioned above does not know what he is talking about. Filling a gas bottle does not go near the regulator unless you are using gas at the same time!"
I've seen, on many posts, that turning off the bottle before refilling, is recommended by some yet others say it is unnecessary. As a punter who isn't an expert on anything, it is difficult to know who is right. So you pays your money and takes your chance!
Basildog
2,213
3,601
He is talking total rubbish
Basildog
2,213
3,601
Regards
P
More rubbish .
The pressure on the downstream side of the regulator will be higher during the refilling.
p-c
134
55
Berkshire
40 years
Then what does the regulator do please?? Yes the upstream pressure will be higher as the liquid going into the CYLINDER, not the pipe to the regulator, compresses the gas that is in the cylinder.
Regards
Basildog
2,213
3,601
Regards
As you know the regulator reduces the pressure but obviously it is subject to the higher pressure involved in the filling process.
