Gas pipes in newish vans.
Hull
Autotrail 634
Since 2006
Is the gas in modern vans 8mm or 10mm?I have measured the diameter with some callipers and it says 8mm.Is it too obvious to assume therefore it will be 8mm pipe and hence i will need 8mm fittings?Thank you.
Gas pipe size can be either 8 mm or 10 mm , depending on what the pipe sizing calculations were 👍
That’s if they did their design correctly.
Ours is 10mm to the manifold then 8mm up to each appliance. You'll probably want compression fittings.
