Gas Pipe Size (2 Viewers)
chrisinplymouth
452
344
Plymouth UK
Adria Compact
hi.... can anybody tell me how to tell if the pipe from regulator to gas distribution manifold is 8mm or 10mm. Mine is plastic coated copper.... do you measure the diameter including the cover, just the copper, or the internal diameter?
TIA
Chris
Silver-Fox
9,269
29,124
Cheltenham Spa
Rapido
im a not so newbie
You could just cut a bit of the plastic of and measure the od. If it’s 10 mm then it’s 8 mm pipe.
Or just measure with plastic on if it’s 11 ish mm its 8mm pipe
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
I always thought the size of the copper pipe was related to the outside diameter (without the plastic protection layer, if present).
The reason being, any couplings or olives are sized to fit the outside diameter of the pipe.
Oct 29, 2016
4,505
52,820
Surrey
Carthago C Tourer
I thought the gas pipes on our Carthago were plastic coated copper pipe also. However closer inspection revealed they were steel pipes with a plastic coating. The end of the 3 way Truma gas manifold valve under the worktop supplying all the appliances had an end plug which I have used to feed a new external BBQ point. On removal of the end plug I discovered that the pipe outlet was 10 mm, not 8mm as I thought it would be. This led to me having to get hold of 10mm to 8mm reduction olive kits, when having fitted I was not happy with.
I then had to have a brass reducer pipe manufactured only 65mm long but going from 10mm to 8mm OD size.
Lesson learned, Truma make distribution manifold valves with 8 or 10mm outlets with the main feed being 12mm in some cases. Carthago fit the 10mm outlet size due to the pipe length to supply heavy usage items like boiler and FF.
Good luck with your install, I was pulling hair out with mine at the time as I could not get to the manifold to fully remove it and replace with a 4 way, which would have been the simplest method.
Les
eddie
8,160
41,280
Taunton Somerset
RV
since 1989
TIA
Chris
What are you trying to do?
Dec 12, 2010
5,415
21,608
Cumbria
As an aside, "pipe" is generally measured and specc'd by it's outside diameter, whereas "tube" is usually specc'd by it's internal diameter or bore.
Silver-Fox
9,269
29,124
Cheltenham Spa
Rapido
im a not so newbie
You are correct (y)
Must of had brain fade earlier :rolleyes:
Apologise for the misinformation.
I’m off to put the dunces hat on and stand in the corner :(
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
To reduce size from 10mm to 8mm I would have just used a solder fitting. Solder fitting are available in all the above mentioned pipe sizes.
chrisinplymouth
chrisinplymouth
452
344
Plymouth UK
Adria Compact
Ah Thought that you were cutting the pipe to add something, which I was going to advise you against lol
@eddievanbitz No just a spare regulator this time, but in the future was going to get a bbq point fitted. Would this involve a manifold change then? Existing one is a 3 way with no spare outlet.
eddie
8,160
41,280
Taunton Somerset
RV
since 1989
It would be easier and safer in my opinion to change for a four way manifold so you have safe and easy shut off for the BBQ point. Having said that I have given up fitting external BBQ points as I always find that they end up in the wrong place.
I use my BBQ under the awning sometimes, sometimes in the Sun, sometimes in the shade of a tree, sometimes carried around to my mates van, all over the place, determined by the weather, what I am cooking and the company. Gas pipes are only supposed to be 1m and even if you double or triple this, I found the BBQ always in the wrong place
So I am back to carrying a small lightweight bottle, so I can BBQ where I want not where I have to be!
chrisinplymouth
chrisinplymouth
452
344
Plymouth UK
Adria Compact
Actually...... that’s a very good point.....
Jul 8, 2023
lunar
I have this regulator which has a 10 on it, so I thought it would be a 10mm one. Is this correct as the pipe seems to look more like 8mm.Thanks for any advice.
PeterCarole29
1,122
1,149
Colchester
Renault Master Fleetwood
20 years
Soldered fitting should not be used on vehicles the vibration can cause them to fail
I dont dispute that at all . i find that suprising compresion joints are considered better. Do you have any reference to that as i may have to change a joint
Jun 29, 2015
3,483
57,536
Southampton
caravan (for now)
on and off since 1984
Compression joint should only be used on accessable positions as they may come loose. I don't have any reference material regarding soldered joints to hand, I have been retired for a while now. I will see if I can find anything tomorrow.
Basildog
2,208
3,591
That’s the year of manufacture
So it’s now 13 years old and should have been replaced at 10 years maximum.
Basically it’s now scrap ☹️😂
Basildog
2,208
3,591
You can only hard solder on leisure vehicles so normal soft soldering is not acceptable, the problem is the vibration can cause the soft solder to migrate from the joints.
Jun 29, 2015
3,483
57,536
Southampton
caravan (for now)
I remember something in the exams but as we never worked on motorhomes I forgot almost all of it until the next exam 😄
53,494
150,297
You shouldn't use soldered joints on wiring in vehicles either.
Feb 16, 2020
2,284
3,103
KT15.
Sunlight. T66. 2019.
Absolute beginners.
You are correct (y)
It happens, I know!!!
Mike.
