Frost protection Autotrail Apache 632
Warrington
a class
6 years
I'm about to drain the water boiler liquid on my 2015 Autotrail Apache 632. The Truma Combi (E) CP plus booklet is clear how to do this is clear. However I cannot find the Safety/Drain valve. Fig 3, p13 gives a diagram with 3 pipes, a circular push button and a rotary switch. Any know the location of this device?
Thanks for any help
Juggler
Have you got anything like this close to your boiler.
I can't find it yet! I think it is hidden with the boiler behind the locker paneling on the drivers side.
I have had quite a few Different models of motor homes and the one common thing was the location of the drain valve ,near to the boiler and close to the pump.
On ours it's right along side the boiler :xsmile:
Mick
Mine I nowhere near the boiler. It’s under my kitchen sink. It can be anywhere on a hot water pipe.
Thanks for any help
Juggler
We had a Scout and ours was in the rear lounge under the seats on the passenger side
In the garage below the boiler wood box it's a simple yellow flip up manual water drain not a Truma Frost Control Valve if it's the same model as this you tube video.
Thanks for any help
Juggler
You problem is not finding it to drain it as it is automatic
Your problem will be finding it to reset it when it comes time to refill !!
Look under the van for an open ended short plastic pipe.. That will be the drain off
Once located out ide it should be easy to find it inside :)
