Front springs (1 Viewer)
Sep 29, 2015
75
31
Ashbourne
Swift Kontiki 645
Since 2013
Hi everyone from sunny Spain- sorry to rub it in for those back home.
I have a Swift Kontiki 645 which to me sits low at the front, needing the use of ramps even on level ground. Has anyone ever fitted stronger/longer springs to raise the front end up. I have seen a couple of others the same as mine.
Thanks Mike
Feb 22, 2011
9,787
20,152
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Ducato ? Jason at ourtour.co.uk did a write up on research he did when changing his.
Think it's a 2001 ducato
Nov 5, 2013
3,101
97,806
Shropshire
Carthago chic e-line
Since 2013
@dave newell lvs replaced ours,Fiat based A class,
before and after !
Feb 21, 2016
4,920
29,539
Uk
C class
Since 2017
Thanks Mike
I was going to suggest that you put a scooter on the back,but that would be just so silly.:D;)
Sep 22, 2009
473
333
nottingham
5 years
On last van goldsmitts in Germany fitted heavy duty front springs for us . Called in as were passing to enquire price,was reasonable, so said when could you fit them answer was 8.00 tomorrow, and you can stop on our free aire
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I think Its built in at the Fiat Factory?. I got to taking notice of it and All the Fiat/Alko combinations I have seen are permanently Nose down. Ours even went on Block Ramps on the drive, as I like the frig to work properly when loading up!
Dec 12, 2010
5,411
21,562
Cumbria
since 2011
It's to do with fuel economy as you're always driving downhill, an idea they pinched from the Citroen 2CV. :LOL:
Apr 17, 2016
508
568
Peterborough, Cambridgeshire
Carthago Chic E Line
Since March 2004
Talk to Mick at SAP at Doncaster. He can supply and fit uprated front springs to relieve this problem. I believe they are supplied by VB the same company that supplies the air suspension kits that Mick fits. He could also fit full air suspension which completely solves the problem and E & P levelling jacks if required. Give him a call as he is very knowledgeable.
Musicboy
191
182
United Kingdom
Rapido 7096+
fulltiming since 2003
Did mine @ 4 weeks ago . A lot of difference ... & better balance of the van re nose diving about bends / roundabouts (noT at speed).
Conrad Anderson did mine ... see thread from me ... So wouldn't recommend them ... as had to clean van after they had their dirty mit's everywhere . Rubbish ...
Anyways ... Yep . Difference I'd very noticeable ... Hardly use the ramps now so it's good ....
