Fridge not cold but ice in the freezer (1 Viewer)
Jul 12, 2013
3,876
5,283
The City of Henlow
Adria Supreme
Since 1980
I had this problem and referred to the handbook, which was no help. I tried the manufacturers agent and local dealers who also could not help. Then spoke to a real engineer who explained it was the heat (cold) transfer mastic that had failed. He explained that I should remove the back panel inside the fridge (through the bit with fins on) there was an ice covered pipe leading to the freezer. The part with fins on should be making cold contact from this pipe with a special thermal transfer paste. It can dry out and fail. Once replaced my fridge worked perfectly.
This is a very simple task BUT at least two of the dealers contacted wanted to fit a new refrigeration unit. Only one person had an answer and buying the thermal mastic was not easy to find, or cheap. Someone suggested using computer heat sink paste. I bought some (cheap). It was like painting the Titanic with a pint of paint. Finally I got the paste from an American RV dealer. One tube should be enough ( about 1/2 litre).
If you need to do this, the job is really simple but not worth doing unless you really have this problem.
Feb 22, 2011
9,819
20,260
Newcastle under Lyme
Hymer B544 A Class
I disagree, it is indeed a cheap and simple fix and in my opinion well worth doing on any older fridge to vastly improve performance.
Mine was barely there and what there was had dried out completely.
Ebay sell the heat sink paste cheaply, I don't know why you had to go to a US RV dealer ?
rosalan
Jul 12, 2013
3,876
5,283
The City of Henlow
Adria Supreme
Since 1980
Ebay at the time wanted approx £30 per tube, they had two left and turned out to be an American RV agent. I bought one, which was mega cheaper than calling out a dealers engineer.
My van was just over 3 years old at the time, and the volume of paste used by the manufacturers was minimal with gaps.
Someone had suggested using paste from computer suppliers. This paste was much more liquid and came in a small squeezy tube, it did not work for me but the real thing did.
tonka
10,838
21,547
Cannock, Staffs
A class Burstner 800
Since 2000
Somewhere on here Is a thread, as I did this last year and posted some pictures to help. Thermal paste / heatsink compound available on eBay 👍
Found it.
May 30, 2019
714
1,031
Aberdeen, UK
Adria Twin Supreme
Since 2018
rosalan , how old is your van? We have a new Adria Twin and have noticed the freezer compartment door getting blocked by ice build up. Is that what you had?
If so photo of fix would be appreciated.
Thanks.
53,557
150,535
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
This was my saga 😊
Aug 25, 2016
1,096
5,753
Taynuilt, UK
Hymer 655 Starline
Village idiot
This is all you need. It’s pc cpu paste as long as you clean off the old stuff. Put this on and you will be happily surprised. It works better than the stuff the fridge manufacturers used
SYY Thermal Paste, 2 Grams CPU Thermal Paste Thermal Compound Paste Heatsink for IC/Processor/CPU/All Coolers, 15.7W/m.k Carbon Based High Performance, Thermal Interface Material, CPU Paste Amazon product ASIN B07BNDPKL5
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
2g definitely wouldn't be enough for my fridge 🤔 depends how big your fridge is though I suppose 😆
rosalan
Jul 12, 2013
3,876
5,283
The City of Henlow
Adria Supreme
Since 1980
My refrigerator problem recurred in the last few days. Once more I removed the 6 star screws holding the delicate alloy fins on. It took a little gentle prising to release the the fins from the paste which had partly stuck to the cold pipe at the back. There were several areas that the paste had not made good contact. I also discovered that there were 6 holes in the plate with fins but crucially 7 screw holes available at the back. I added a new hole, and fresh non-setting thermal paste where it had not stuck before. All units must be very different for I needed more like 1/2 a cupful of paste, having previously tried the paste used in computers with no success.
As said by others, this is a very easy job but take care to refit the temperature sensor without breaking te plastic as I did.
Aug 25, 2016
1,096
5,753
Taynuilt, UK
Hymer 655 Starline
Village idiot
Using to much heat sink paste is just as bad as zero. You only want to put paste on the very top or side the contact patch of the black metal tube that’s got the coolant in it. And the aluminium back of the fins should be a clean as possible. Even polished is better. Then it’s just a thin contact with the pâté on the tube tighten and bobs your trans anti. To much paste and it won’t cool as it should.
Sep 28, 2015
2,024
2,622
Hymer B544
2001 Caravans 2011 Motorhomes
A fine example of the benefits of being on MF.
Hopefully this will improve the performance of our fridge, the freezer is fine. Dometic RMD8505.
T25 Torx bit screwdriver, scraper, thermal grease, some paper towel for the old grease and about 20 minutes work.
I used one and half tubes, guided by the amount that was on.
68c
Oct 22, 2019
1,822
2,804
Southampton
2001 Pilote 270
On older models there is a window in the bottom left hand of the fridge compartment. You should be able to see a blue flame clearly. On newer models you need to remove the metal shield around the jet assembly accessed by the lower external cover. You can see the flame once the lower metal shield is removed. I just removed the screw on the left side of the shield and gently bent it clear. The flame should be at least an inch high, blue with only the faintest of yellow at the tip. On mine it was hard to start and had only a small flame. I found the sintered metal filter in the fitting to the jet had gummed up. Washed with meths and blow dried. Flame normal and easily seen through the little window.
